20 Most Recent
Samsung Q1 Tablet PC Questions & Answers
Hard Drive
Format the drive and delete the partition first
Hey, my touch pad seems
First, check if the device came with an installation disk. This disk is the driver for your device. Try to reinstall the driver first. If that didn't help, contact the manufacturer and have them upgrade the firmware of your device because there could be a possibility that the program got corrupted or something.
If the same problem occur, then that's the time you will go to check the physical parts of it.
Have a great day!
Relating to ram
I am not sure what motherboard you have, but I would suspect that your computer will take at least 2 sticks of 512 MB each.
You didn't say what operating system you are using. If you are using Windows 98, 128 MB is fine. If you are using Windows XP, you should have at least 10x that, or 1GB to run correctly.
You really do need to know how much memory your computer will support, so you can go on the manufacturer's site and look it up or use the manual that came with the computer, if you still have it.
My ivso bluetooth keyboard does not hold its charge. What could be the issue and how do I fix it?
- Battery issue: The battery in the keyboard may be faulty or have a low capacity, which can cause it to quickly drain and not hold a charge.
- Charging issue: The charging port or cable may be damaged, preventing the battery from charging properly.
- Keyboard software issue: There may be a software issue with the keyboard that's preventing it from charging correctly or retaining a charge.
- Connectivity issue: The keyboard may not be compatible with your Samsung tablet, or there may be a Bluetooth connectivity issue that's causing the battery to drain quickly.
It is recommended to have the issue diagnosed by a qualified technician or customer support for the keyboard manufacturer. They can diagnose the issue and provide a solution to resolve the problem. Ignoring the issue could lead to further damage and increased repair costs in the future.
