20 Most Recent
HP Pavillion DV6227 Notebook Questions & Answers
Discover Bluetooth Device Not Available
uninstalled the rom
bad idea that.! why mess with ROM. ouch.
test the PC on other BT devices, if it works then the PC is good.
even a BT head set, mouse, or any other vast numbers of BT devices, (not apple sure)
Network drivers are not worke
Instructions
Check which communication port
and interrupt your modem is set to use. Typically, these are hard-wired
selections on the board itself. Changing the jumpers on the board
changes the port address and interrupt number. You must give forethought
to the consequences of the decision. There are only two interrupt lines
usable and four port addresses that are possible. Only one port can
utilize an interrupt number at a time.
Change the port and interrupt
assignment if required. Restart your system and see if this solves the
problems. If not, find the documentation for your modem. You must now
generate the proper initialization string for your modem to maximize
your communications. Some of the settings in the initialization string
determine the audible sound of the modem when dialing and connecting.
More important settings have to do with number of rings to wait before
hanging up, time to wait between redials, sensitivity of the modem to
line noise and enabling or disabling the transfer mode of X2 or V.90
(the two formats for 56K communication).
Find the modem driver that you
are using and check that it is the correct driver. There are many
drivers available based on manufacturer and model of the modem. Not only
is the driver modem specific but also the recommended initialization
string. Make sure your modem receives the correct initialization string
in the setup file or preference window in the application that uses the
modem.
The charging indicator light no longer comes on
Possibly a failed or damaged charging port (does it feel loose)? After that, charger may not be chucking out the voltage (19.5 volts)? Test with multimeter set to DV volts, with one probe on the inside of the plug ant the other on the outside.
Does the charger LED light blink when connected (sign that power is not making a circuit)
If the above fail to work, then the problem is with the connector on the mobo, this may just be a Charger port needing replacing (wired or soldered version), or the charging circuit of the motherboard gone
Hp pavillion dv6227 pc notebook black screen
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
My dv6700 will start up and run for awhile then
It sounds like an overheating problem. Try using some compressed air to blow out any debris from the ventilation slots along the edge and bottom where the fan is. Be sure the fan is in deed working also.
I am not able to
I request you to visit the link mentioned below
http://support.microsoft.com/kb/917607
Also, I would appreciate if you provide more information about the issue.
What is error message?
What kind of application are you trying to open? etc.
Thanks and regards
My hp pavillion dv5t-1000 power cord not working
Test your voltage on your power supply...There should be a voltage amount on the sticker on your power supply telling the output.Make sure yours is putting out the right amount.If this test good,your probally looking at a bad dc jack.Jacks need to be checked by a certified repair person.....Goodluck......If this is helpful ...Be so kind as to give a testimonial.....Thank you
MY HP PAVILLION 6262 LAPTOP WONT POWER UP, LIGHTS
see if you can boot into safe mode
as the pc starts tap F8 - should be presented with a menu - choose "safe mode" from the menu
if that works, then try a system restore to before the problem started
start>programs>accessories>system tools>system restore
choose a date before the problem started
reboot
I have a wierless laptop
Please update the driver of the wireless card and then try again it seems to be a driver problem.
Why the computer wirelss
Thank you for contacting fixya , but it seems that your problem is not that clear so in order for us to provide the proper solution for your problem please do explain your problem further.
I have a Hp laptop but it wont play any You tube
If you cannot play it in your browser,then go to adobe and download the latest version of adobe flash player plugin, close your browser and install it. Open your browser and try again. You should be ok now.
All the best.
