20 Most Recent Toshiba Sattelite A105-S2071 Notebook Questions & Answers
On some models this prompt reads Press F12 for boot menu. On others, it may say Press C to boot from CD-ROM. On still others, there may be a row of colored icons representing the various boot devices (HDD, FDD, CD, LAN, PCMCIA, etc.) Press F12 while these icons are displayed, and then use the arrow keys to move the cursor from one to another. As new models are released, the wording of these prompts may change.
Immediately after pressing the power-on button, press the hotkey for the device from which you wish to boot:
HotkeyBoots from deviceCIDE CD-ROM1FISA FDD2UUSB FDD3Ninternal LAN adapter4
Toshiba... | Answered on Oct 06, 2017
Sounds like video bad on motherboard
Toshiba... | Answered on Mar 15, 2015
If you want to change the boot just for one time press and hold F12 during the booting proces but if you want the computer to boot every time in USB mode you must press F2 to enter the bios setup, look for the boot priority option chnage save, exit and restar.
Enjoy
Toshiba... | Answered on May 15, 2014
The max RAM upgrade is 2Gb.
For further info. check out this WEB site.
http://www.memory-up.com/memory/ToshibaSatellite3811.html
Toshiba... | Answered on Feb 01, 2013
If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Toshiba... | Answered on Aug 02, 2012
hello. can you explain exactly what is happening.
Does the bios boot up? Does the operating system start assuming windows xp? Are you looking to recover previous work or a fresh install?
Toshiba... | Answered on Mar 29, 2012
You can download thedevice drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsphttp://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Toshiba... | Answered on Mar 19, 2012
Muy sencillo solo manten precionada la tecla Alt y marca 164 (ñ) para minuscula y 165 (ñ) para mayuscula pero de todas maneras visita este link http://www.datines.com/2009/06/atajos-de-teclado-windows/ que te ayudara mucho la informacion en esa pagina. Suerte y gacias por usar FixYa.com
Toshiba... | Answered on Jan 07, 2011
Please check that the RAM is the correct type. Also some older models may not support more then 1GB of RAM. After inserting the RAM ensure that you have it has been placed in the slot properly and correctly.
Toshiba... | Answered on Dec 30, 2010
512MB(min)
2048MB (max)
2 memory slots using 256MB, 512MB, 1024MB or 2048MB PC4200 DDR2 533MHz SDRAM, dualchannel
support requires two memory modules of same capacity and clockspeed
I usually go to Tigerdirect to get my customers parts.
Here is the site and the type of ram you need.
http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=10&sel=Detail;30_170_12847_12847,Detail;30_1225_47516_47516
Hope this helps!
Toshiba... | Answered on Dec 15, 2010
If this is a hard drive problem and you can't afford to lose the data, I can recommend SpinRite by GRC. It isn't free or shareware but is the best around.
I used it for many generations of PCs and it rarely failed to recover a dead or dying hard drive.
SpinRite
Toshiba... | Answered on Nov 23, 2010
Your media player doesn't support very well the dvd format. Replace it with the best one there is
http://www.videolan.org/vlc/
Toshiba... | Answered on Jun 21, 2010
Desired Letter
How to Make It:
In MSWord
3 number code
Hold down theAlt key and type:
4 number code
Hold down the Alt key and type:
Spanish
á
Ctrl+' then a
160
0225
é
Ctrl+' then e
130
0233
í
Ctrl+' then i
161
0237
ñ
Ctrl+Shift+~ then n
164
0241
ó
Ctrl+í then o
162
0243
ú
Ctrl+' then u
163
0250
ü
Ctrl+Shift+: then u
129
0252
Alt+Ctrl+Shift+?
168
0191
Alt+Ctrl+Shift+!
173
0161
Toshiba... | Answered on May 02, 2010
When you load the cd and reboot, when you see the toshiba screen, start tapping F12, see if this brings up the temporary boot menu, if it does choose the cd and watch closely for "press any key". If there is nothing showing, might I suggest you get an external cd drive that attaches by usb. You will then have to get back to the BIOS and set the usb as your first boot device and try to boot again from the usb cd drive. Good luck.
Toshiba... | Answered on Apr 14, 2010
Does the fan run?If it does, try using a laptop cooldeck...laptops sitting on flat desk,ect. have a tendacy of getting overheated and shutting down..Walmart or Target sells cooldecks...a good one will cost about $40
Toshiba... | Answered on Mar 20, 2010
Hi, right click on the Desktop Screen; select from the "View Icon sizes in the window, "medium, small..." If the solution helped, rating it is appreciated, thanks
Toshiba... | Answered on Mar 19, 2010
1st install UAA sound driver from Microsoft
then ur system detect sound driver......try it
Toshiba... | Answered on Mar 10, 2010
Toshiba Sattelite A105-S2071 Notebook Logo
Popular Tags
55 questions posted
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Computers & Internet
Most Popular Question
upgrade a105 s2071 1 stick memory 4gig
  • Computers & Internet
