20 Most Recent Twinhead SlimNote N12PI Notebook PC Questions & Answers
is this any good https://restore.solutions/en/philipsfreeventsx51/
Twinhead... | Answered on Nov 03, 2017
deriversforfree.com
underneath there should be a small trap door secured with a screw. With the laptop off, unscrew this door and remove the old chips by pushing out of the side clips. lift out old ones and insert new ones, paying attention to the slot in the chip lining up with the motherboard and then push in and lay it back. Put back trap door
first check your wifi status . if status are disable please enable it .if it already enable but doesn;t work .please try to re install a wireless driver .
Twinhead... | Answered on Sep 18, 2013
Hi.
As the Computer is displaying an error message "Operating System not found", you may perform a BIOS reset and check if the issue is resolved.
1) To reset the BIOS, boot the Computer to the BIOS.
2) Once you are in the BIOS, please try pressing the F9 key.
3) The F9 key should be the shortcut key to reset the BIOS.
4) However, you will also have the option to reset the BIOS in any of the tabs in the BIOS main menu.
Please try performing the above steps which I have mentioned and let me know the results.
Hope this helps.
Please feel free to contact for further information and assistance.
Twinhead... | Answered on Oct 02, 2010
I cant see your model here, but here is your driver download page
http://www.twinhead.com.tw/taiwan/download.aspx
Twinhead... | Answered on Aug 07, 2010
sometimes there is a slide lock next to the hatch...
sometimes they hide screws under stickers, its an easy way to varify that the user didnt open the case. use a phillips on that inconspicuos round sticker.
Twinhead... | Answered on Jun 25, 2010
Are you on battery mode?
If you are in battery mode, remove your laptop battery, plug in the adaptor to the laptop (without the battery) and plug to the power outlet. Turn on your laptop.
Twinhead... | Answered on May 22, 2010
Try removing its HDD and another removable disk. Finally the RAM module. If does not, take it for repairs.
Twinhead... | Answered on Apr 28, 2010
the video card could have been damaged.
Twinhead... | Answered on Mar 29, 2010
you need to reinstall your operating system again...no other go...try installing with the help of the operating system CD provided along with the computer...
try to go to device manager and check if on your adapter is a yellow question mark if it`s there that means that your lan driver have been uninstalled or try to goo in network connections and see if the lan card is disabled
Twinhead... | Answered on Mar 15, 2010
Please you need to replace the fan then.
Twinhead... | Answered on Jan 27, 2010
Have you tried booting in safe mode pressing F8 when starting up just after you power up, then a menu appears & you can try sytem restore from there or safe mode if you know what to get rid of on the system.
If not boot with a copy of windows in the drive & start again from fresh!
Hope this help's !
Twinhead... | Answered on Sep 23, 2009
Are you sure you have all the screws out, there is a small plastic disc on the bottom of the laptop underneath the card slot, this needs to be removed to access a screw (obviously take out plastic blank in slot first).
And there is not much reason to dismantle LCD either.
What is it you are trying to do.
Twinhead... | Answered on Jul 20, 2009
Twinhead SlimNote N12PI Notebook PC Logo
Popular Tags
40 questions posted
Top Twinhead Computers & Internet Experts
Toby Lee
Toby Lee
Davit Mamyan
Davit Mamyan
Jay Plesset
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Twinhead Computers & Internet
Most Popular Question
twinhead efio 121i dead
  • Computers & Internet
