20 Most Recent Lexmark C772dn Laser Printer Questions & Answers
What is the driver and where can I grt it fot Lexmark p3150
Go to Lexmark website enter the model number and get driver and/or complete printer install download for free.
3/14/2016 4:06:11 AM • Lexmark C772dn... • Answered on Mar 14, 2016
149.05 c782 error
Not a very fast job if you end up having to replace the motor itself. But thats the fuser motor PN = 40X1661. You can pull the fuser out look to the right side and see a white gear find. A lot of time that gear or the ones around it are worn out. Every now and then its just the fuser itself has broken gears or something is stuck in the gear.
7/24/2014 9:56:22 PM • Lexmark C772dn... • Answered on Jul 24, 2014
tip
How to install a Lexmark printer when the software setup CD is lost
Lexmark does not distribute replacement install disk for all models.
Contact Lexmark here, to see if the disk for your printer is available.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Lexmark C772 displays "149.05 - SERVICE Motor Erros"
click on this link. http://support.lexmark.com/index?productCode=LEXMARK_C522&segment=SUPPORT&pmv=print&page=content&actp=TOP_DOCS&id=SO3607&locale=en&userlocale=EN_US
4/16/2014 1:39:01 AM • Lexmark C772dn... • Answered on Apr 16, 2014
2answers
100.01 Services ITU Error, Lexmark
From the Lemark Service manual
A 100.01 ITU error indicates that the printer did not detect the ITU belt home sensor. Before proceeding with this
service check, make sure that the Second Transfer Roll is correctly installed. After you reinstall the Second
Transfer Roll, check to see if a 100.01 ITU error is still displayed. If a 100.01 ITU error is still being displayed,
continue with this check.
The ITU has an optical sensor that watches for a piece of reflective tape on the inside of the image belt. This
tape is read every revolution of the belt. If a signal is not received from the belt sensor within a certain time
period, the printer posts an error due to the loss of signal. There are several causes for the loss of signal. First,
the belt has tracked too far to the front or rear of the printer. In this case, the belt is still turning, but the reflective
tape is no longer passing within view of the belt sensor. This is considered a belt tracking error and is initially
posted as a 100.02 ITU Error. The other causes of a signal loss could be a belt stall, meaning the belt is not
turning, or a true signal loss, which would be due to a bad sensor, broken cable, loose connection, or bad
system board. These other causes post as a 100.01 ITU Error.
To assist the printer in determining the cause of a signal loss, there is a buffer that records the belt position for
the last 50 revolutions. If the printer loses the belt signal, it refers to the buffer. If the buffer shows significant
mistracking before signal loss, it will post a 100.02 ITU Error. If the buffer shows that the belt has been tracking
in the center before signal loss, it posts a 100.01 ITU Error. Due to memory restrictions, the buffer is not saved
during POR. This means if a printer posts a 100.02 ITU Error, so the belt is tracked off, and the customer or
servicer turns off the printer to clear the error, when the printer starts up, it will still not see the belt signal and will
now post a 100.01 ITU Error because the buffer is empty. When servicing a printer for a 100.01 ITU Error, it is
important to view the error log. See "Display Log" on page 3-29. The error log can only be displayed at this
point. Do not try to print the log. Look for past occurrences of 100.01 ITU Errors preceded by a 100.02 ITU Error.
2/4/2013 4:28:45 PM • Lexmark C772dn... • Answered on Feb 04, 2013
There not sofware for lexmak x2670
You may download software and drivers from here.
1/12/2013 1:48:18 PM • Lexmark C772dn... • Answered on Jan 12, 2013
2answers
Continuous ink system for HP4280 printer
Hello there I am from the Philippines just like you and that one is easy...
We have the same printer. contact me in this email.
[email protected]
12/29/2012 12:21:36 PM • Lexmark C772dn... • Answered on Dec 29, 2012
What dose a usb cord look like
a usb cord is an extension cord for you to used in case your usb ports is loose, it differs in length according to your neeeds
12/11/2012 2:10:13 PM • Lexmark C772dn... • Answered on Dec 11, 2012
Lexmark c772 when printing it make load Laud noise
Please power off the printer. Remove all the toner cartridges. And then put them back in. Make sure you install the toner cartridges properly. After that power on the printer. Try printing again.
8/29/2012 9:01:33 PM • Lexmark C772dn... • Answered on Aug 29, 2012
I dont have the cd installation for my lexmark x5470
kindly download the driver from this linkhttp://en.kioskea.net/download/download-895-driver-lexmark-x5470
Hope this helps. Please rate my response.Thanks.Have a good day.
2/18/2012 7:18:00 AM • Lexmark C772dn... • Answered on Feb 18, 2012
I'm having a problem scanningto
Fix this Error - use an advanced registry cleaner for Windows that allows you to safely scan, clean, and repair registry problems with a few simple mouse clicks. Problems with the Windows Registry are a common cause of Windows crashes and error messages. By using PC tune-up utilities such as registry cleaners regularly, your system will be more stable, your software will run quicker, and your operating system will boot faster.
http://www.errorfixreviews.org/
or you can try this option Solution#1- If your printer does not show in your hardware list its means that problem belongs to data cable. Kindly check your printer's data cable and plug it properly.
Solution#2- Uninstall printer's software take a reboot and then reinstall its software and then attach your printer or during installation if installation requires.
Good Luck
8/30/2011 6:28:05 AM • Lexmark C772dn... • Answered on Aug 30, 2011
Lexmark C772dn Laser Printer Logo
Popular Tags
55 questions posted
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Marvin
Marvin
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
C Lexmark
  • C Lexmark
Most Popular Question
not sofware lexmak x2670
  • Office Equipment & Supplies
