20 Most Recent Sylvania 6626LCT 26 in. LCD Television Questions & Answers
i had my power supply blow on mine within the first year took it in because i had extended warranty and they fixed it, only problem was finding a dealer in my area to fix it, then took over a week, because of customer support issues
Sylvania 6626LCT... • Answered on Aug 02, 2018
As for the 10-20 secs ,tv turns off .......I have one of those ......Im still trying to fix mine, without buying a new board ,I will post results!
Sylvania 6626LCT... • Answered on Jan 20, 2016
next to the fuse that blows is 4 large black diodes2.gif.one of those is common to short out. the bad one would give you areading of zero ohms when checked with a meter. or just replace all 4.most likely its location D603. hope this helps
Sylvania 6626LCT... • Answered on Jun 14, 2013
A blown fuse is usually caused by a shorted regulator or a bridge rectifier circuit. Either way it is a problem in the primary power supply. A bad cord won't blow the fuse in the set, it will blow a circuit breaker in the house. A servicer usually would normally cover the inside of the set with a "few light slits in the AC cord". Hope this helps
Sylvania 6626LCT... • Answered on Mar 04, 2013
Hi, Check all connection on the back. If all is good, go to a repairman. Good luck
Sylvania 6626LCT... • Answered on Jan 14, 2012
Watch some HD or other 16:9 programming. If you have pillarboxes on the sides it is likely that you are watching a 4:3 program that doesn't fit your TV's screen. When people upgrade from a "regular" TV to a "widescreen" model they changed the shape of the TV but didn't change the shape of 60+ years of TV programming, the only ways to force the "square peg" to fit the "rectangular hole" is to either chop off the top and bottom of the image or to stretch it. I highly recommend against either of these as "Stretch-O-Vision" is just wrong because it makes people look fat and turns car tires and other circles into short fat ovals.
Sylvania 6626LCT... • Answered on Aug 03, 2011
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem, and do take care in handling the problem....
Sylvania 6626LCT... • Answered on Jul 06, 2011
Now the tv turn on,the tv have power and the LED power light indicator to the tv have stable power?Yes?Just a black blank LCD screen panel?Yes,than the only thing is wrong for this tv problems it is the tv Tuner signal board.That the board,where the incomming broastcasting signal cable wire plug into this board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Sylvania 6626LCT... • Answered on Apr 08, 2011
The tv Tuner signal board it the problems and the causes.That the board,where the tv incomming broadcasting signal cable wire plug into it.U can take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Sylvania 6626LCT... • Answered on Mar 21, 2011
Hi richgun,
Click this link http://dl.owneriq.net/e/e48faa76-28d7-4e6f-9988-891f8f0a17af.pdf. Perform page 18.
Hope It may help you.
Have a nice day!
Thanks for using Fixya.
Sylvania 6626LCT... • Answered on Mar 18, 2011
Sylvania 6626LCT 26 in. LCD Television Logo
73 questions posted
Top Sylvania Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
lost sound from possible
  • Televison & Video
