20 Most Recent Canon ZR800 Mini DV Digital Camcorder Questions & Answers
'off' in a camera shaped icon appears
Contact Canon service centre
6/28/2017 5:13:25 PM • Canon ZR800 Mini... • Answered on Jun 28, 2017
0answers
Computer doesn recognize camera
Have you downloaded the drivers for that camera: http://www.usa.canon.com/cusa/support/consumer/camcorders/minidv_camcorders/zr800#DriversAndSoftwareAlso if it still doesn't work try taking the memorycard out of the camera and reading it using a memory card reader.
10/10/2013 10:18:22 PM • Canon ZR800 Mini... • Answered on Oct 10, 2013
Help!
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off.
1/12/2013 5:31:09 AM • Canon ZR800 Mini... • Answered on Jan 12, 2013
When i try to play
since you have use a tape cleaner and it did not work,the only solution is to change the play head
9/16/2011 5:12:18 PM • Canon ZR800 Mini... • Answered on Sep 16, 2011
How do I get the time stamp to show up on the
download it to the computer
3/5/2011 7:44:30 PM • Canon ZR800 Mini... • Answered on Mar 05, 2011
Electrical appears to be dead. With adapter
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
12/19/2010 6:01:32 PM • Canon ZR800 Mini... • Answered on Dec 19, 2010
Its like the camera part of the unit quit working
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
12/19/2010 5:45:24 PM • Canon ZR800 Mini... • Answered on Dec 19, 2010
My new computer only has
Most Windows PCs have USB ports, but no Firewire port. As your PC did not come with this interface, you need to fit an add-on Firewire interface card in one of the bus slots. This will come with a driver for the card. I am assuming a desktop PC, you don't say what kind of computer it is. If it is a laptop, you won't be able to fit a card. You can get Firewire interface cards from Amazon or eBay quite cheaply.
11/23/2010 7:31:52 PM • Canon ZR800 Mini... • Answered on Nov 23, 2010
Not sure what cord to
Depends on the Mac unit you have. If your MAC has a firewire 400 port, then use the firewire cable that came with your camera. Just connect the cable to the camera and the other end to the mac. iMovieHD is already loaded - with the camcorder in "Play" mode, you will "Import" the video.
If your Mac does not have a firewire 400 and just a firewire 800, you need an adapter. Click on this link to see that adapter.
Thank you for using Fixya and your generous rating will be much appreciated. If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
10/20/2010 5:24:40 AM • Canon ZR800 Mini... • Answered on Oct 20, 2010
Turn on camera and inserted
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
9/8/2010 3:43:08 PM • Canon ZR800 Mini... • Answered on Sep 08, 2010
I have a canon zr800,
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
9/7/2010 1:03:38 AM • Canon ZR800 Mini... • Answered on Sep 07, 2010
My canon zr800 screen is not working, just a blank
try mains power??
5/19/2010 12:38:35 PM • Canon ZR800 Mini... • Answered on May 19, 2010
How can I find out if my Canon ZR800 has DV
Yes, it does. According to the manual (found here http://gdlp01.c-wss.com/gds/0/0900000700/02/ZR800NIM-EN.pdf) on pages 42-43, you can hook the camera up to a monitor with an HD (IEEE 1394) connection as seen on page 42. If you are looking for digital pass through to a PC, you'll have to download the drivers at Canon's website to get it to work with a web cam software.
4/8/2010 4:16:04 PM • Canon ZR800 Mini... • Answered on Apr 08, 2010
Computer reconized canon zr85, but not the zr800
load or reload the drivers for the zr 800,you should be able to get the drivers off of canons website
3/26/2010 5:33:50 PM • Canon ZR800 Mini... • Answered on Mar 26, 2010
On a Canon ZR800 I cannot find the connector cord to the computer
you need a Firewire cable. Hope that helps.
2/12/2010 1:42:14 AM • Canon ZR800 Mini... • Answered on Feb 12, 2010
Where is the memory card located on the camera
there is no memory card slot, this camcorder uses miniDV tape.
2/12/2010 12:13:43 AM • Canon ZR800 Mini... • Answered on Feb 12, 2010
Canon ZR800 Mini DV Digital Camcorder Logo
78 questions posted
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
ZR Canon
  • ZR Canon
Most Popular Question
flashing red symbol screen not no
  • Video Cameras
