20 Most Recent
Canon PowerShot G7 Digital Camera Questions & Answers
Check with the Connectors, and upgrade to the latest firmware by placing it to a working unit.
Canon PowerShot...
Answered
on Feb 18, 2015
There is no way to restart it without having the lens error serviced first. Why they say restart is ridiculous, it doesn't restart! If you need to have it repaired, this is the best place for the Canon's:
www.CamerasAndParts.com They are $89 for parts, labor and return shipping - plus they clean and service the camera too! They only service Canons, they are the ones we recommend exclusively, the work through them is excellent and about half the cost of most shops.
Canon PowerShot...
Answered
on Jan 03, 2015
Most likely a loose screw shorted out the power in the camera. For service on these, we recommend www.CamerasAndParts.com They are the best for service on the Canon Powershots and they are not expensive at all. I'll post a video below from a customer referral for this problem on the G7 to them. They are the place for help with this problem.
Canon PowerShot...
Answered
on Jan 03, 2015
Since your camera is a Canon and you are experiencing a lens error message, we'd refer you to this site:
www.camerasandparts.com They just do the Canons, they aren't expensive at all and the work through them on the Powershots is superb! They'd be the place to help you on this one. Their service package for the lens error on the G7 is $89 with the parts / labor included , the servicing for the camera is covered, plus the shipping on the way back is included. The best part with them is their work is excellent on the Canons. Hopefully that helps to get you going with it. Good luck
Canon PowerShot...
Answered
on Nov 19, 2014
Hello :
It seems that the batteries are dead [ can't be recharged anymore ] . You need to replace them with new batteries . If you are sure that the batteries are fine , then you may check the base where the batteries set . Maybe it's rusty or some isolation stuff on it . If it's clean , then I recommend you to get your Cam to the service .
good luck .
please rate !
Canon PowerShot...
Answered
on Nov 19, 2014
Usually you can't hear the loose screws in these when they fall out and short out the camera, although many people will say you can. When you have no power on a G7 or a G9, it is most always that loose screw problem. The screws inside should be corrected at the time of the repair so the problem doesn't happen again later. The site that is great for help with the Canon Powershot Camera problems is: www.camerasandparts.com They are great with these and that is all they specialize in. I would see if they can help, they're amazing if you need a hand with the Powershots, plus they do that no power correction on all G7 and G9's they service which I like. Good luck with it
Canon PowerShot...
Answered
on Nov 07, 2014
This no power problem on the G7 is most often causes by a loose screw in the camera which shorts it out leaving the camera not powering on. If you need to have it serviced, a great place for these is:
www.camerasandparts.com All they service are the Canons and the work through them is superb. That no power repair through them is $89 with parts / labor included, the servicing for the camera covered, plus the shipping going back is included. The best part is they do a correction inside the camera so this doesn't keep happening. If you need help with it, they'd be the place for this one. Good luck with it.
Canon PowerShot...
Answered
on Nov 07, 2014
I don't have one in front of me, but you might just need to turn "auto white balance" on.
Canon PowerShot...
Answered
on Oct 22, 2014
That often happens as a result of a short on this model. Try emailing them at this site: www.camerasandparts.com They service the Canon Powershot cameras exclusively and they do excellent work, all for about half of what Canon wants. If you need help with it, that site is the place for a Powershot. They are excellent, send them an email and I'm sure they can help you with this problem. Good luck.
Canon PowerShot...
Answered
on Feb 04, 2013
This is most often what happens when the flash in the camera goes out. If you need to have it serviced, this place is great for the Canon Powershots:
www.camerasandparts.com All they service are the Canons and the work through them is superb. They are not expensive at all and the best part is they do excellent work on these models. Hopefully they can help you with it. Good luck.
Canon PowerShot...
Answered
on Aug 22, 2012
