20 Most Recent Sony BRAVIA KDL-52XBR3 Television Questions & Answers
2answers
KDL52XBR3 Sony Bravia turns off automatically
Tv power supply board is having problems,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
7/19/2013 10:18:15 AM • Sony BRAVIA... • Answered on Jul 19, 2013
Sony bravia black screen audio ok
It is a LCD set and if sound get it in a very dark room and with a flashlight and the set on look to see if you see a very faint image on the screen.Almost all these sets use a back light system for brightness---an inverter of some type to power the lights---either the back light is bad or the voltage for it is not present or being turned on.
11/5/2012 9:38:08 PM • Sony BRAVIA... • Answered on Nov 05, 2012
I have a sony KDL52XBR3 I have sound but no picture!
It sounds like a shotgun estimate to me--those are Sony part numbers for circuit boards--Google each number to see if available. Also Google the model number with "parts".I have heard this song before--some shops only want to collect some money and are not interested in fixing the set.A way out for them is to say part not available---If they only looked at the set in your home that is not good enough--a complete exam would require it being in a shop with the proper test equipment to really see if 2 boards need to be replaced--also in a shop they might be able to find something that cannot be found in the home.Keep in mind (our shop) that the techs in the shop (the top ones) rarely go to the home---you usually get a less experienced tech there.Do some research and if find the boards are available point that out to the shop you had out and let Sony know about this.
6/1/2012 3:35:03 PM • Sony BRAVIA... • Answered on Jun 01, 2012
3answers
I have a sony bravi xbr ;the picture is sooo big i can't read the subtitles . i tried ti fix it ( from the instruction manual ) but nothing work . thank you !
Hi: Check you screens format button to change screen sizes, this button may also be labeled Aspect. Seems you are in ZOOM Mode, these buttons can also be found on cable boxes remote as well try pushing them to see if screen size change. If this does'nt help then do this with the TV in off posistion. Press the Display key on your remote, Then the Five key, then the Vol up key, then press power key. This will turn set on in service mode, you will see service options do not do anything but press the number 8 on remote and hit enter. This will rest tv to factory settings. All video setups and parameters you have set in user menu will result back to factory and will need to be redone. TV should shut down on its own and come back on on channel 3.
12/11/2011 1:36:33 PM • Sony BRAVIA... • Answered on Dec 11, 2011
0answers
Sony Bravia LCD half screen is darker shade sometimes
Magnetic fields don't affect lcd screens, unlike crt tvs where a magnet can cause problems. If it is only a slight difference i have seen this before even on my tv. if you go to a blank screen you can see patches of light and dark, they call this bruising, i have talked to sony engineers about this but i have not got a straight answer as to what makes this happen, if the tv is in warranty a tech will replace the panel, if it is not in warranty it is not cost effective to replace. But the good news is that is does not seem to get any worse with time, it is more of a manufacturing defect that most will not notice. Look at the tv with dark blank screen and you may see areas where the screen is lighter than the other. If you see this than you have this issue. it will fade off and will not be a stark line. Also I noticed that there is a software update for your television go to www.sony.com to get a download of the software, or sony will send it to you free of charge.
10/20/2009 2:47:09 PM • Sony BRAVIA... • Answered on Oct 20, 2009
Sony 65 inch TV, KD-65X750F not getting any power from stand-by pin on power board?
Do you get voltage with the main board unhooked?
3/27/2022 11:56:41 PM • Sony BRAVIA... • Answered on Mar 27, 2022
Sony 49 XBR 900 E power will not come on unless the plug is taken out from the set and reconnected. Can you tell me which board should be replaced?
what plug not told./PC is dead?no it is not a PC it is a television posted to wrong forumnow corrected.is TV set to sleep mode, RTM read the manual on TVare the clicker remote batteries fresh>?
3/24/2022 2:55:41 PM • Sony BRAVIA... • Answered on Mar 24, 2022
How can I watch Netflix on a tv Sony wega that isn’t hooked to the internet. It’s wirelessly connected to Vizio ( smart tv Netflix built in) but I want to be able to watch in a different room
netflix is a 100% internet web site , streaming site. thus the net in flix. what did you mean by hooked?\ do you have internet at home at all? do other things in home work to the internet, like PC or cell phones. what I can not under stand is (different room) this phase implies some rooms do work (netflex) and wifi gets weak if my move any TV farther from the home router and will fail past 25 feet or more. wifi is super weak through walls for sure brick, or 2 walls. if home is small one wifi access point is all you need if huge home more. distance matter, TV to router. no TV model # told. (tells me wifi spec) if you said my TV works in room 1 but not room 2, wifi;. it be super more easy to answer.. is this true? if true , get a tech to upgrade your wifi. or go wired, Ethernet.(a better home upgrade)
3/24/2022 2:24:22 PM • Sony BRAVIA... • Answered on Mar 24, 2022
I need to remove the back off a Sony Bravia KD-48X81J
The front and back pieces are like a clam shell and are compression fit with tabs into one another. You need to use something like a guitar pick or spudger to separate the pieces. Dont use metal objects due to damage that will happen to the plastic .
2/21/2022 10:19:19 AM • Sony BRAVIA... • Answered on Feb 21, 2022
I have a 85 inch Sony Bravia TV. I have sound but no picture
Hello !! what do you mean by you replaced the video card ? mainboard or t-con ? , we need more information
2/1/2022 12:21:49 AM • Sony BRAVIA... • Answered on Feb 01, 2022
Sony bravia 40" kdl-40v3000 stand screws
They are usually M6 or M8. You can get them from Home Depot or Sainsbury Homebase.. These are listed as the correct ones. https://www.ebay.com/itm/4-STAND-FIXING-SCREWS-FOR-SONY-KDL-40U3000-KDL-40V3000-KDL-40D3000-KDL40W3000-TV-/322578615461 and here as well, the same type https://www.ebay.co.uk/itm/272144950454?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338722076&customid=&toolid=10050 ..
11/30/2021 5:53:30 PM • Sony BRAVIA... • Answered on Nov 30, 2021
I have Sony Bravia 32r402a with demo loop running. Also the power light blinks many times thereafter input select tv/hdmi/video keeps flashing. Any action for remedy?
Sounds like a bad main board, or more specific the EEPROM is bad on the main
11/13/2021 8:41:51 PM • Sony BRAVIA... • Answered on Nov 13, 2021
Why does my Sony Bravia TV keep going to standby?
Check power supply caps
10/18/2021 12:22:02 PM • Sony BRAVIA... • Answered on Oct 18, 2021
Sony Bravia KDL-50R550A keeps turning on and off after 15 seconds? Changed batteries & unplugged 60 seconds. Should I reset?
You can try but I don't think that will help, sounds like power supply issues, open the back and look for bulged caps
10/11/2021 12:09:29 AM • Sony BRAVIA... • Answered on Oct 11, 2021
No sound some channels
HI IN THIS CASE YOU LED TV CHANG AUDIO FORMATE PLEASE GO TO TUNING SECTION THEN IN FINE TUNING AND THERE IS SOUND OPTIOND LIKE BG DK I AND M SELECT ONE ACCORDING TO YOUR COUNTRY THANKS M NASIR
10/3/2021 4:54:49 PM • Sony BRAVIA... • Answered on Oct 03, 2021
Hi, I've Sony Brevia LCD tv model # kdl 32bx300. Its displaying green discolored pictures. Is it T Con board problem or main board issue?
Hi dear its main board problem and some time LVDS FFC cable problem . thanks M Nasir
10/1/2021 6:19:26 PM • Sony BRAVIA... • Answered on Oct 01, 2021
Sony BRAVIA KDL-52XBR3 Television Logo
10 questions posted
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
sony bravia lcd half screen darker shade
  • Televison & Video
