20 Most Recent Samsung SyncMaster 731B 17" LCD Monitor Questions & Answers
When small square appears in the upper left hand
Ahaa, Beth... Yours is a older and tired puppy. You already know it's only 17" so "details" are SO easy to miss... even WHEN it's working! (I will whisper to you that it MAY be your power supply failing?) (*whispers) ... eBay 232038053660 $11.99 USA seller) Soooo... since money IS a issue (for most of us)... consider this: Go to GOOGLE and search for: "Craigslist North Carolina" Find the city nearest to you and HUNT ~ and HUNT for the best used 21" (or so) monitor you can afford. OF COURSE you will INSIST that they "demo" monitor BEFORE you pass the bux. WHY invest in repairs or diagnostics for a broken monitor your TECH may not be able to get parts for?? IF it can be repaired, at what price for labor+parts and WHAT will fail again? Beth, I found a past FIXYA Link that HAS your manual WITH a "Troubleshooting" section! The other Link describes problems others have had with your same model... So there you have it! FILM at 11:00! Anthony
12/15/2017 4:41:00 AM • Samsung... • Answered on Dec 15, 2017
Russian to english controls
please check if there any language settings then change to english
2/14/2014 7:14:23 AM • Samsung... • Answered on Feb 14, 2014
Have a Samsung SyncMaster 731B (Black) 17 inch LCD
Might be a case of the backlight giving up. If this is the case, you have two options, replace the backlight (expensive and pretty difficult to do a good job of) or replace the whole thing. I'd go with the second option, as LCD monitors are pretty cheap at the moment! Stick with Samsung SyncMasters though, they do good price monitors that are reasonably reliable too. Either that or a Dell monitor.
Thanks
Moza805
8/30/2011 2:07:25 PM • Samsung... • Answered on Aug 30, 2011
Samsung Synchmaster731b monitor stuck
Well, I have few questions. What if you unplug the monitor from the computer and turn it On? Have you tried the monitor on another system? Have you tried with another monitor on the System?
Things you can try: 1. Reseat the Ram/s and make sure they are properly/securely seated.
2. If you have video card installed on your computer, reseat the video card.
3. Reset the Bios, you can do this by removing the system battery on the motherboard or enter the Bios settings and restore it to "Default.."
Please post back with more details if nothing seems helpful.
Good Luck.
5/11/2011 4:04:49 PM • Samsung... • Answered on May 11, 2011
Upon starting my PC the
You need to try this monitor with another PC and also check all the cables and the connection first.
Most SAMSUNG monitors has three years warranty.
Otherwise it may have basd caps problem; http://s807.photobucket.com/albums/yy352/budm/Samsung%20730B/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
4/22/2011 4:12:05 PM • Samsung... • Answered on Apr 22, 2011
2answers
Smeared image
Try removing signal cable and refitting at both ends.
Signal cable also could be faulty.
Samir
4/20/2011 1:23:35 AM • Samsung... • Answered on Apr 20, 2011
The blue light is blinking
It does the same when used with another PC?
If it is the monitor then please read here:
4/5/2011 3:26:42 PM • Samsung... • Answered on Apr 05, 2011
Screen comes on during startup for only a second
That issue is normally caused by the backlight in the LCD. The compact florescent light in the display is burning out. They will normally light for a few seconds when first powered on, then shutoff.
Ultimately, the bulb needs to be replaced. If your into hacking electronics, you can get a replacement bulb online and DIY. Otherwise, the cost of having it repaired is usually very close if not more than a new monitor.
3/24/2011 1:29:17 PM • Samsung... • Answered on Mar 24, 2011
My Samsung 731BF Monitor has recently started
The problem is most likely the backlight or the power supply that feeds the backlight. The bulb will be the most common problem and will likely require replacement. For the cost of replacing the bulb, you would be better of replacing the monitor.
Just keep doing your power reset technique and use it till it dies.
3/10/2011 4:43:03 PM • Samsung... • Answered on Mar 10, 2011
Monitor brightness is dull at
It may have dying power supply due to bad caps, that will be the first place to check.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
2/25/2011 7:00:12 PM • Samsung... • Answered on Feb 25, 2011
It doesn`t show any picture.
It does the same when attached to another PC?
2/24/2011 7:44:45 PM • Samsung... • Answered on Feb 24, 2011
This is my 2nd monitor.
What is it not doing?
Most common problem in LCD monitors are due to bad caps a syou can see in my SAMSUNG albums here:
2/4/2011 3:52:56 PM • Samsung... • Answered on Feb 04, 2011
I have a samsung 731b 17' that works, but I have a
No, the 19" uses more power to drive the lamps, and the power supply will not be the same to interface with the logic board either.
What kind of problem you have with the 250bw?
1/31/2011 5:10:15 AM • Samsung... • Answered on Jan 31, 2011
Where can i get a
I've had good results with the Cold Cathode Fluorescent Lamp (CCFL) tubes from Moniserv's parts site. In particular, check out the tech support page.
1/23/2011 3:58:10 AM • Samsung... • Answered on Jan 23, 2011
It starts to turn on and then after a second goes
It does the same on another PC/
1/11/2011 7:35:01 PM • Samsung... • Answered on Jan 11, 2011
Screen light dim
Probably the screen backlight starting to go
1/9/2011 11:15:35 PM • Samsung... • Answered on Jan 09, 2011
Samsung SyncMaster 731B 17" LCD Monitor Logo
76 questions posted
Top Samsung Computers & Internet Experts
Muzahura Frank
Marvin
Marvin
Fix It Fast...
Fix It Fast...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
samsung syncmaster 731b black 17 inch
  • Computers & Internet
