20 Most Recent Sony BRAVIA KDL-32S2010 32 in. LCD Television Questions & Answers
Image burn from leaving it on.. Its the vertical colors we get when we disconnect everything.. Its stand by screen.. It won't get worse.. But u either have to replace it.. Or live with it..
Sony BRAVIA... | Answered on Feb 06, 2018
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sony BRAVIA... | Answered on Mar 27, 2017
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sony BRAVIA... | Answered on Aug 28, 2016
This TV will work in Australia as its multi system and auto-power TV.
Sony BRAVIA... | Answered on Jul 31, 2013
Are you on mute by accident? If not your sound circuit needs repair.
Or the power supply line power distribuition.Some voltage is missing
to the sound circuit.
Sony BRAVIA... | Answered on Nov 01, 2012
OCP ( Over Current Protection ) 02. This is the fault. Contact any experienced service tech; This is not a user repairable fault.
Sony BRAVIA... | Answered on Aug 13, 2012
If the VGA is working it is not likely a main board but could be. Google the model number with "parts" or visit shopjimmy.com with the model number.
Sony BRAVIA... | Answered on Jun 01, 2012
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
Sony BRAVIA... | Answered on May 22, 2012
Hello dcbio77,
Welcome and thank you for using FixYa!
Your tuner board is the issue here. It can be checked for bad soldier joints, or replaced.
Have a great evening!
Sony BRAVIA... | Answered on Sep 09, 2011
try autoprogramming at different times. signal may be better during the day than at night, and vice-versa.
Sony BRAVIA... | Answered on May 07, 2011
The sattelite box have issues,tries unplug,replug the box back like about an hour later for it to reboot and resetting and upgrading it softwares.This tv problems switching modes to digital and to analog again back and forth should be solved.Still happening the box have problems,call ur sattelite provider change the reciever box.
Sony BRAVIA... | Answered on Apr 04, 2011
Let me know how many times its light flashing after 3 seconds pause, this is an error code that has info about defective section of tv, it will help me to diagnose problem and to suggest solution.
Just to confirm, is it Sony KDL-32S2010 lcd tv as mentioned in question headings or any other model.
Thanks
Sony BRAVIA... | Answered on Mar 07, 2011
POSSIBLE FAULTY SCREEN OR LVDS LEAD CONNECTION PROBLEM
Sony BRAVIA... | Answered on Jan 12, 2011
If you get no picture at all, not light is visible on the screen, it may means that the backlight inverter board has gone out, or the power supply that supply the voltage to the inverter board has gone out. Use a flash light flush on the screen to see if you can see any thing at all.
Sony BRAVIA... | Answered on Oct 11, 2010
Try contacting www.shopjimmy.com
It is not going to be cheap if you can get one, it will be more than the TV is worth.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Sony BRAVIA... | Answered on Jul 10, 2010
Check to see if you do have good clean 12vdc feeding the T-CON board.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Sony BRAVIA... | Answered on Jul 04, 2010
Sony BRAVIA KDL-32S2010 32 in. LCD Television Logo
47 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
sony kdl32s2010 turns immediately goes
  • Televison & Video
