20 Most Recent Panasonic TH-37PX60U 37 in. Plasma HDTV Questions & Answers
Will not turn on after power outage. Is there a reset button?
No, no reset button. Some sircuit of your TV was victim of poser surge, typical to power outaget events. Flat TVs are paerticularly sensible to power issues. You'll have to take it to repair To protect your TV buy a surge protector Top Rated in Surge Protectors
6/19/2015 9:36:04 PM • Panasonic... • Answered on Jun 19, 2015
Have a Panasonic TH-37PX60U tv - can I hook it up to a HD Satellite receiver - have a Bell hd but don't get any reception
Your plasma tv will display HD content when you connect an HD source (Blu Ray Disk, Sony PS3 / PS4 or Xbox 360, HD Cable Box, HD satellite, etc) via the TV's HDMI1, HDMI2, Component1, Component2 jacks or if you connect a UHF/VHF TV antenna (not cable box, etc.) to the "Ant" connector *and* you're close enough to a broadcaster with HD content to view. Using any other input will produce only the lesser quality SD video signals. Review the manual - linked below - to help you connect the components you have. http://service.us.panasonic.com/OPERMANPDF/TH37PX60U.PDF
5/13/2015 1:05:19 AM • Panasonic... • Answered on May 13, 2015
We have a Panasonic TV - Model TH-37PX60U
Sometimes that "chirping" is caused by loose windings on various transformers. You can usually isolate a particular transformer by pressing on it when it is "chirping" & it may stop "chirping" or the frequency my change. If that is the cause, you can A: replace the coil, B: replace the Printed Circuit Board, or C: Do nothing as it really isn't hurting anything but your nerves.
3/5/2015 11:56:25 PM • Panasonic... • Answered on Mar 05, 2015
How do I get the volume to work, it doesn't work manually or with the controls
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
11/19/2014 1:50:20 AM • Panasonic... • Answered on Nov 19, 2014
0answers
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
2/9/2014 11:55:53 PM • Panasonic... • Answered on Feb 09, 2014
Can Nt program TV because I do not remember
yes, and you can get nthe 4 digit code by googling it on the internet.spin
10/18/2013 9:30:28 PM • Panasonic... • Answered on Oct 18, 2013
2answers
Panel locked
Remote needed:
When Panel Lock is set to ON, the buttons (SOURCE, MENU, VOLUME, SELECT, MUTE, POWER) on
the front of the PDP will not operate. However, these buttons will operate when setting Key Lock OFF.
1 Press the Menu button. Move the joystick up or
down to select “SETUP”, then press the joystick
to enter.
2 Move the joystick up or down to select “Panel
Lock”, then move the joystick left or right to select
“On” or “Off”.
3 Press the Menu button to exit.
10/2/2012 2:10:06 AM • Panasonic... • Answered on Oct 02, 2012
Just shut itself off and now won't power back on
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_29_2012_12_45_30_am.jpg
4/29/2012 12:45:39 AM • Panasonic... • Answered on Apr 29, 2012
Is there a fuse for the power
Yes there is---requires back cover be safely removed: follow the power cord which will go to it.
4/29/2012 12:44:01 AM • Panasonic... • Answered on Apr 29, 2012
Panasonic Tv model TH-37PX60U turn
WIGLE WIGLE WIGLE WIGLE YEA!!
2/1/2012 4:01:29 PM • Panasonic... • Answered on Feb 01, 2012
2answers
HOW DO I RETUNE AFTER DIGITAL SWITCHOVER
Free PDF Instruction Manual at the link below shows how retune on Page 28.
You can do this at any time but after Digital Switchover you'll lose all Analogue Channels.
http://service.us.panasonic.com/OPERMANPDF/TH37PX60U.pdf
6/24/2011 7:18:54 PM • Panasonic... • Answered on Jun 24, 2011
Panasonic TH-37PX60U 37 in. Plasma HDTV Logo
66 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
TH Panasonic
  • TH Panasonic
Most Popular Question
retune after digital switchover
  • Televison & Video
