20 Most Recent HP iPAQ hx2790 Pocket PC Questions & Answers
i just cried a river for you, If I saw it in a garage sale for $1 id buy it and crush it so others cant suffer like you, no really. batteries inside both are gone, some are solder in too. opps. what good is this thing in 2017? tell me love to hear it. buy used smart phone that has support. why not ask HP, we are not. ask them and hear load laughter,,or worse. sorry but all ours are in the landfill making bad ground water. https://h30434.www3.hp.com/
HP iPAQ hx2790... • Answered on Oct 13, 2017
PCM, Backup the data on the card to a computer. Format the card. Try on your iPAC. If still not recognized. the format in a different computer. Try on your iPAC. Repeat the process till it is recognized by your phone. When and if you get fed up of trying, throw the card away as useless/unusable.
HP iPAQ hx2790... • Answered on Jul 04, 2011
try going in to power settings while in the cradle, tap backlight and set it so it doesnt go off. Worked for me!
HP iPAQ hx2790... • Answered on Aug 22, 2009
Most webcams connect to a Type A USB port. The specifications, https://support.hp.com/id-en/document/c06696087 , indicate that there are 4 Type A USB ports on the rear of the system for the S01-PF1013W. The system also has four Type A USB ports on the front of the machine. Type A USB ports are rectangular and the cable can only be inserted one way. You can see the position of the front USB ports here: https://www.walmart.com/ip/HP-Slim-Desktop-Tower-Celeron-4GB-1TB-Desktop-Tower/353685973 . They are aligned vertically on the right hand side of the tower between the combination headphone/microphone jack (3.5 MM round port) and the SD card slot. You should be able to use any of these ports that aren't in use for other devices. If you plan on disconnecting the web cam often, it may be easier to use the front USB ports. If you do not have a free USB port, consider using a USB hub for some devices. Sometimes the surrounding metal can bend and the cable connection will be loose or the port will not let you push the connector into the port. Then the device will not stay connected properly; you may see repeated "new hardware found" or similar messages. A small flat blade screwdriver may be used to adjust this surround. Make sure to turn off the computer and unplug the power cable before attempting this. Note: USB ports can fail. If the device isn't working, try a different port. However, the ports are wired in pairs. Thus one pair may fail at the same time. This most often happens if a device pulls too much power. Some USB hubs with many connected devices and charging certain devices used to be the primary causes of this problem. I hope this helps. Cindy Wells (If your webcam has an independently wired microphone, you should plug that into the front combination headphone/microphone port or the rear microphone port.)
HP Computers &... • Answered 5 hours ago
The keys on your laptop computer needs to be replaced and have a person that repairs and fixes computers to have a look at your laptop and see if the keys can be repaired or not for your laptop.
HP Computers &... • Answered on May 04, 2021
windows 7??????????????????????i went to hp.com and there is only XP and W7 support on this 12 year old pC, this is A FACT.what OS is there.?in the run box, type start run, type, WINVER,(ENTER)BINGO OS , TOLD NOW, if windows. of Linux say LINUX.!"I Installed .synaptics drivers " you said.from where? HP.com w7 or XPor from the 1million infected driver websites from H3LLor from maker synaptics.com or?where ?now my longer answer for only w7 ok.1: be internet connected first are you, on bad PC. MUST BE.2: in device manager go to mouse and pointing devices. (conrol panel (CP) click Device manager)see Synaptics there , and right click it and and choose uninstalll device.3: now reboot PC, by start + shut down.4 off it is.5: push power button 10 seconds and release (resets PC)6: go to step2 above make sure synaptics looks happy there. does it, no errors?7: now go to CP + mouse and check all settings here.on HP they are not simple, some have 2 drivers working there for synaptics pad, one for the pad and one for buttons.only HP.com drivers work, for sure true on all my Eitebooks here.use only HP.com drivers. no others. or it will failand the driver needs to match YOUR UNSTATED OS.I sure hope you did not get w10 here. it does not belong here.NO OS TOLD why in the world post lacking such a very very key fact, why>??after all Drivers match OS.
HP Computers &... • Answered on May 03, 2021
sadly the only place i can suggest is a computer repair shop
HP Computers &... • Answered on Apr 27, 2021
If you are lucky the drive may just need plugging back in, but I suspect the board may be damaged if the BIOS cannot 'see' it.
HP Computers &... • Answered on Apr 26, 2021
music download software http://100-downloads.com/download.php?p=682 spotify Instant and legal access to over 10 million music tracks http://www.artistdirect.com/music http://mobile.afreecodec.com/free-songs-download-87079.html once the music starts to download a browse option will open where you will need to select if you want to run or safe
you should always keep your antivirus up to date when using any file sharing programs on the internet
hope this helps
HP Computers &... • Answered on Apr 15, 2021
Have a look at the user manual for precise instructions.
HP Computers &... • Answered on Apr 03, 2021
HARD DISK MAINTENANCE TO KEEP COMPUTER RUNNING EFFICIENTLY. Hard disk maintenance should be carried once a month to make your computer run efficiently. This removes redundant and temporary files, recovers disk space and speed up hard disk access. Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too. Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment. When this is completed repeat these steps for the D Drive if you have a D drive. Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
HP iPAQ  hx2790 Pocket PC Logo
9 questions posted
Top HP Computers & Internet Experts
Michael Thomas
Michael Thomas
Davit Mamyan
Davit Mamyan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iPAQ HP
  • iPAQ HP
Most Popular Question
ipaq hx2790b battery not hold power
  • Computers & Internet
