20 Most Recent Syntax Olevia 537H Television Questions & Answers
Olevia is not picking up my cable channels
pick up the remote turn on tv....press menu...setup....tv....then channel scan....(note your tv should also be on cable broadcast not air)...hope this is helpful
1/21/2015 5:31:48 PM • Syntax Olevia... • Answered on Jan 21, 2015
2answers
I need the firmware for an olevia 237-s11 can you
hi you can download a firmware from the below attached link
http://rapid4me.com/?q=olevia+237+s11+firmware+download
1/20/2013 3:35:14 PM • Syntax Olevia... • Answered on Jan 20, 2013
Good picture no sound
Check your video cables,
10/2/2012 5:49:06 AM • Syntax Olevia... • Answered on Oct 02, 2012
2answers
I can get to the
I have the same problem. Cable went out, hooked up an antenna and it scanned ok. Hooked up a diff amplified ant, worked the same. So watched videos. Next morning tuner would no longer scan or add channels. Now it will not even factory reset. Get to Auto Scan and it goes no further, cable or air.
9/6/2012 12:24:35 AM • Syntax Olevia... • Answered on Sep 06, 2012
Need olevia 437 S11 firmware
There is no firmware to this TV by internet. Contact the nearest authorized service center for help.
8/21/2012 2:10:18 PM • Syntax Olevia... • Answered on Aug 21, 2012
Troubleshooting an Olevia remote that wont channel up, it goes into mute
if the remote works use that===sounds like a defective microswitch on the control board on front or side of set--not uncommon.
5/14/2012 1:23:24 PM • Syntax Olevia... • Answered on May 14, 2012
Olevia 537 keeps turning off
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_23_2012_5_08_51_pm.jpg
4/23/2012 5:08:58 PM • Syntax Olevia... • Answered on Apr 23, 2012
Oversize image
Check your aspect ratio on your TV and on your cable or sat box.
4/11/2012 3:43:43 PM • Syntax Olevia... • Answered on Apr 11, 2012
Olevia 537H power button stays on tv randomly turns on
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.3_31_2012_4_14_01_pm.jpg
3/31/2012 4:14:10 PM • Syntax Olevia... • Answered on Mar 31, 2012
537H-B11 For the first 20-30 seconds no response
I have the same exact problem, it's so damn frustrating.
8/10/2011 4:24:50 AM • Syntax Olevia... • Answered on Aug 10, 2011
After lighting storm no input other then the RF
Hi
The power surges that lightning usually brings effects the tv from a blown fuse to a damaged board .You need a technician to have it checked. Check all of the inputs to the TV to ensure you still have signal there (you might need to borrow another TV to do this). If the problem is not your signal source, then it's the TV and the news may be bad. If you did not have the TV plugged into a surge protector, the power line problem may have fried something in the TV's power supply. Power supply problems on TVs are easier to repair than many other faults, so an evaluation at a repair center might be worthwhile. Failing that, then you need a new TV. Also try replacing burnt/shorted hi-volt cap C421 470pf/2kv.
Please gets back to us if you have further query else please accept the suggestion.Thank you for contacting fixya.com
4/21/2011 5:23:24 PM • Syntax Olevia... • Answered on Apr 21, 2011
Blue power light is on but no picture......olevia
I have a Syntax Olevia 532-b12 and ironically, the blue light is on when power is off (and turns off when the power is on...) I assume it's the same for the 537H
3/5/2011 10:24:06 PM • Syntax Olevia... • Answered on Mar 05, 2011
0answers
Comcast sent a signal out
Comcast should be liable. This happened to me with my Olevia 437V Since Olevia went out of business and has no support your options are limited. You could take it to a local repair shop, although they may have problems getting any parts unless they can do a PCB level repair. It may be as easy as the tuner chip. There is a firmware upgrade but I no longer can find it, when it was available it was like $30. There tech stated that the upgrade wasn't related to the tuner but I was a little skeptical that maybe the DTV format was different than how the TV was original designed to accept. You maybe able to just get an external digital tuner also.
Olevia phone number: 866-965-3842
I'd never buy another thing from them, they left all there customers in the lurch.
11/24/2010 1:17:46 AM • Syntax Olevia... • Answered on Nov 24, 2010
Olevia 537B11 bluie light is on but will not trun on
That can be the problem in the main logic board. You need to look at the sinal generated by the power switch to see if it is there. Also need to look at the power supply DC filter caps and check the voltages to make sure they are OK.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
7/8/2010 3:16:54 AM • Syntax Olevia... • Answered on Jul 08, 2010
Good morning, i`m looking for the Olevia 537H
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320519042058&rvr_id=&crlp=1_263602_263622&UA=%3F*F%3F&GUID=6b0d4c971280a0b584467926fffb5f6e&itemid=320519042058&ff4=263602_263622
Is the ownly place I have found one
5/25/2010 4:57:42 AM • Syntax Olevia... • Answered on May 25, 2010
My remote wont work how do i reprogram it
you don't you will either have to gaet a univeral or go to mr remote .com and purchase a refurbed or replacement
4/19/2010 12:37:47 AM • Syntax Olevia... • Answered on Apr 19, 2010
Syntax Olevia 537H Television Logo
59 questions posted
Top Syntax Televison & Video Experts
Jaime Hernandez
Kolbrun...
ray gallant
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Syntax Televison & Video
Most Popular Question
after lighting storm no input other rf
  • Televison & Video
