20 Most Recent Garmin StreetPilot c530 GPS Receiver Questions & Answers
Take it back to the 'secure location' as indicated in your service manual. It will automatically unlock when it gets a full satellite signal. You have to enter the PIN number twice when setting up the unit. You should always use a number which is familiar to you so you can remember it. If you can't remember it, and if your secure location doesn't unlock the unit, you will need to send the unit to Garmin to unlock it. You will need your receipt for Garmin to unlock the unit.
Garmin... • Answered on May 31, 2009
When you first setup the GPS, you can setup a safe location, go back to your safe location, there will be not lock on it then.
Regards
Garmin... • Answered on May 26, 2009
Pop the face off to reset it, could sort it for you.
Press the power button for over 1 minute to calibrate the screen
and use the Garmin Web-updater to update the software.
Should be good then
Regards
Richard.
Garmin... • Answered on May 19, 2009
Pull the face off, press reset button under it,
then update it at Garmin's Web-updater website.
If it wiil not reset like this
Press the lower right corner of the screen, while turning on, keep pressing until the message
" do you want to remove all data " appears, click yes
Then re-register it at Garmin, then re-update it at Garmin
Should be good then
Regards
Richard.
Go here... Find Map Updates Either enter your serial number or download Garmin Express to find any updates for your device. Keep in mind that if your device is over a year old you may be charged an upgrade fee...
Garmin... • Answered on Aug 19, 2014
go into the settings and turn off simulator mode... or the device is dead. call Garmin to see what they can do 1800-800-1020
Garmin... • Answered on Aug 09, 2014
get a new unit... the street pilot series is outdated and it's a miracle that your unit is still working at all. Celebrate that you have gotten 10+ years out of that unit and go get your self a Dezl or RV unit
Garmin... • Answered on Aug 05, 2014
Hi Paulette,Many Garmin GPS units that only get powered by the car charger / cradle suffer from this problem eventually. The fix is pretty simple. You didn't include your model GPS, but I think this may help just the same:Connect the GPS to a computer's USB port, or AC adapter that has a USB port and leave on for 8 hours (or over night). Disconnect and and turn on again. If you have a Nuvi that has a spring return sliding power switch - slide and hold it in the on position for 15 seconds before letting go. It should power up just fine. You do not need to hold the power switch like this again to turn it on.If the GPS starts acting like this again, simply repeat the process as often as needed. Eventually, the internal battery will no longer be able to accept a charge and will require replacement.Good luck!
Garmin... • Answered on Jan 31, 2012
perhaps it needs new batteries
Garmin GPS • Answered on May 11, 2021
Well, Garmin Express is compatible with all versions of windows above Vista, 7, 8, or 10. It is also compatible with the Mac operating system.
Garmin GPS • Answered on May 03, 2021
along with all the different devices for the navigation, outdoor activities, and fitness, the Garmin has also given an application to manage these is called Garmin ExpressYou can download Garmin express from the website for free: https://i-garmin.com/express/
Garmin GPS • Answered on Apr 24, 2021
Download Garmin Express to the computer, register the Device and then connect the Nuvi. Very simple and fast.
n?vi 57/58/67/68 - Updating Maps and Software with Garmin ...
www8.garmin.com > nuvi57-58-67-68 > EN-US
You can use Garmin Express™ software to download and install the latest map ... large, and this process may take a long time on slower Internet connections.
Garmin GPS • Answered on Mar 04, 2021
Contact Garmin to inquire.
Garmin GPS • Answered on Nov 24, 2020
By operating the power switch and holding it in the off position until your Nuvi shuts down
This is usually done through a computer or laptop. Create an account on the Garmin website. Connect your Sat-Nav to the computer. You should be able to download the updates through your account.
Garmin StreetPilot  c530 GPS Receiver Logo
4 questions posted
Top Garmin GPS Experts
Sheldon Dedek
Tom Chichester
Bill Boyd
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
StreetPilot Garmin
  • StreetPilot Garmin
Most Popular Question
help me unlock gps not remember pin
  • GPS
