20 Most Recent Syntax Olevia 532H 32 in. LCD HDTV Questions & Answers
My TV does not work, pressing the remote control on the blue light flashes
From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
9/22/2015 12:26:08 PM • Syntax Olevia... • Answered on Sep 22, 2015
What is the likely problem, and is it likely to be expensive?
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
5/5/2015 6:16:11 PM • Syntax Olevia... • Answered on May 05, 2015
How do I scan for channels using an antenna?
Sounds like tuner fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
9/22/2014 1:38:24 PM • Syntax Olevia... • Answered on Sep 22, 2014
0answers
Need remote codes for olevia tv model 532b12
037,033,038,031. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts. http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/
12/13/2013 12:49:17 PM • Syntax Olevia... • Answered on Dec 13, 2013
2answers
I have an olevia 242T FHD LCD HDTV model. I dont
You need an external antenna, you could use an indoor or outdoor, whatever you want but as long as you have one.
7/2/2013 6:21:46 PM • Syntax Olevia... • Answered on Jul 02, 2013
I have an olevia 532 b12 model and no tv channels in list
I have an olevia 532 b12 model. I do have cable at my house, straight to tv , no cable box.. but my tv only says a message ''no channels in list'' on the Turner source option. I Just bought this TV with no manual, What do I do in order to see the channels , to me it seems like the remote is locked. I cant change the time date , nothing ? The DVD playes plays and sounds great,,, Its just the cable TV part
Thanks
6/30/2013 5:01:41 AM • Syntax Olevia... • Answered on Jun 30, 2013
Olevia 532 base stand screw
hi, did you find your answer? I have the same problem. [email protected]
4/7/2013 4:23:44 AM • Syntax Olevia... • Answered on Apr 07, 2013
0answers
Blue light on but wont turn on
Check and replace the main digital board. It is a skilled work. It will be best to contact any experienced service technician. If you wish to get more details, check this site.
3/22/2013 5:08:40 PM • Syntax Olevia... • Answered on Mar 22, 2013
How to reset the parent control on my Olevia 532H
how to reset the parent control on my Olevia 532H
10/15/2012 7:17:33 PM • Syntax Olevia... • Answered on Oct 15, 2012
Hi my TV recenly had no power supply. Had tried
The problem is inside the TV.
The SMPS (Power supply) may be faulty. To be repaired
If you are not Technicaly compatent then contact any service centre.
5/13/2011 9:03:52 AM • Syntax Olevia... • Answered on May 13, 2011
2answers
Does ovelia model 532 B-12
I purchased a 532-b12 several years ago - it includes both an analog and digital tuner.
5/7/2011 11:24:09 PM • Syntax Olevia... • Answered on May 07, 2011
0answers
Syntax Olevia 532H 32 in. LCD HDTV Logo
59 questions posted
Top Syntax Televison & Video Experts
Jaime Hernandez
Kolbrun...
ray gallant
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Syntax Televison & Video
Most Popular Question
ovelia model 532 b 12
  • Televison & Video
