20 Most Recent
Dell UltraSharp 2407WFP 24" LCD Monitor Questions & Answers
Can I watch TV (Dish TV) on my Dell Ultrasharp 2407WFP ?
No. Monitors are different from TV's and are not able to connect directly to a Dish receiver. The frequencies the monitor uses are different that a TV. You can get video from a PC into a TV but not vice versa. You can use the second UHF output from the VIP 722 to connect an older TV without a digital tuner in it to that port. It will come out on channel 73 and will not be Hi def. You'll need to use the remote with the #2 on it to operate the receiver
Dell 2407wfpb lights on but stays blank..
Shine a bright light on the screen and press the Menu button... if you can barely see the outline of the menu come up in the middle of the screen, it means that your inverter / backlight needs to be replaced. You can get a new backlight / inverter for relatively cheap, so if you can do the repair yourself, it's worthwhile.
Otherwise it's the LCD panel itself, in which case you should go monitor shopping.
I can Fix It if I Can Find The inverter.
Cajun is an idiot. a BACKLIGHT is a pencil sized tube that provides light for the LCD. An inverter will take a small voltage and turn it into a large voltage, with a proportional decrese in current. Not nearly the same thing.
Go to LCDrepairs.com and buy the parts you need.
Hi Team, I have Dell Ultra Sharp Monitor which
If you are not an electronics tech It would be remiss to advise you to interfere with a high tension device like a monitor. take it to where it can be serviced and keep your life. Only experienced people should open up a monitor and poke around 22000 volts is involved here and if its overheating the wiring on th ecoilod ids breaking doen or has broken down.
How do I remove the back cover on a Dell 2407 WFP?
Hi, I can't offer you a fix for your overheat problem, but here's how to get into the 2407WFP!
Place the monitor face down on the bench. Remove the four screws from the back.
Turn the monitor over and lay on its back. With your fingertips gently ease the front bezel from the glass, starting far away from the buttons and not putting too much pressure on the glass. It comes away with a series of clicks.
I managed this easily, but if your fingers aren't strong enough you could use a lever (you MUST spread the load on the glass so as not to break it, and avoid doing too much damage to the plastic of the bezel!)
Work your way all the way round snapping the bezel from the front, but don't completely remove it as this will strain the ribbon cable from the buttons.
Lift the screen and rest it on one edge, and you will find the back starts to come free from the insides.
Carefully lay it flat on its bezel again and lift the main rear casing away.
You are in! To get at all the boards:
Undo the 8 gold-coloured screws from around the edge of the central metal cover (not the four which hold the VESA-mount in place) and all three covers can then be removed to expose the backlight inverter board, power supply board (very similar to the one in the 2405FPW, see related articles if the PSU is your problem), main controller, and USBhub/card reader PCB.
Hope that helps you - now to find out why it's bust!
Chris Colborne - Technician, Diamond Light Source (UK)
Dell 2407 24" monitor gets a green cast
It sounds like you could have a bad video cable. Check to make sure your cable is plugged securely to both the monitor and the computer. If it is, remove the cable and check for bent pins in the cable.
If you have a spare cable, I would just try switching it to cut down on troubleshooting the cable.
2407 screen goes black
faulty connector... need to call a repair guy to solder a connection.. usually 50 bucks
