20 Most Recent
Samsung SyncMaster 940N 19 inch LCD Monitor Questions & Answers
Moved my computer and now
Be sure computer is actually starting. Power off then on computer you should see the boot sequence and then windows screen on monitor. If you do not see startup sequence monitor is not sleeping either the monitor has failed or the video card has failed. Try another monitor first.
10/16/2017 10:07:14 PM •
Samsung...
Answered
on Oct 16, 2017
My samsung 940N acts like a florescent tube, tries
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
2/13/2010 6:01:57 PM •
Samsung...
Answered
on Feb 13, 2010
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
1/28/2009 10:53:08 PM •
Samsung...
Answered
on Jan 28, 2009
How to fix pink colur screen on sync master 794 mg samsung
The connecting cable or the video card would be the first suspects. Try a different cable to connect the monitor first, if there is no change, the video card in the computer would be second to look at. Can simply connect a different monitor to your computer to troubleshoot this. If the testing monitor works, it will be the graphics card that is the issue.
6/19/2022 1:41:48 PM •
Samsung...
Answered
on Jun 19, 2022
Vga connection to the mother board
If your motherboard doesn't have a VGA connection, then that means it most likely does not have an integrated video card. If this is the case, then you will have to purchase and install a video card. It is very easy and your local Best Buy should be a great resource. The geeks there are usually very enthusiastic about explaining how to do it. I use to order from newegg.com, but they have become very commercialized and overpriced, like Best Buy. You can check tigerdirect.com or my favorite Amazon.com. Best Buy will price match any items they sell, including those on Amazon. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_3e83613ef5f2a68b
3/13/2015 12:06:38 PM •
Samsung...
Answered
on Mar 13, 2015
