20 Most Recent Olympus Camedia C-480 Zoom Digital Camera Questions & Answers
When I put completely new batteries in, it keeps saying "battery empty" in the window? Have tried several new batteries and is refusing all of them?
You could try using 2 x AA NiMH rechargeable battery or2 x AA NiCd rechargeable batteries if you just using ordinary AA batteries at the moment......
5/1/2014 10:07:17 AM • Olympus Camedia... • Answered on May 01, 2014
A picture error has appeared on one of my photos
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101[[
8/27/2011 8:02:34 PM • Olympus Camedia... • Answered on Aug 27, 2011
2answers
How to correct RUNTIME error
Please elaborate on the description of your problem.
The more information you provide, the more specific and accurate our solutions can be.
I see no reference to a RUNTIME error related to your Olympus C-480 camera online or in the users manuals.
Is RUNTIME a word you are seeing on your cameras screen or on your computer while running software related to your camera?
4/15/2010 2:21:53 PM • Olympus Camedia... • Answered on Apr 15, 2010
tip
Olympus Camedia C-480 Advanced Manual
Models: X-550, D-545 Zoom, C-480 Zoom
Have you lost the Operating Instructions for your Olympus Camedia C-480?
Click here to download a digital, searchable copy of the advanced users manual / owners guide.
I hope that helps.
_____________________________________
The Olympus Camedia C-480 Basic Manual is available here.
tip
Click here to download a digital, searchable copy of the basic users manual / owners guide.
I hope that helps.
The Olympus Camedia C-480 Advanced Manual is available here.
How can I turn off
The write protect is usually a small micro switch on the memory card. Pull it out and make sure the switch is not locked. It's located on the edge of one side of the card..
3/4/2010 4:59:53 AM • Olympus Camedia... • Answered on Mar 04, 2010
Removal of write protection
Sounds like you will need to format the internal memory of the camera. This will permanently erase all the data from the memory and then you will be able to use it again. To format the memory: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the memory can be used again.
5/10/2009 1:46:07 AM • Olympus Camedia... • Answered on May 10, 2009
Camera mode dosn't function. Play mode functions.
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced.
Olympus will charge a flat rate repair fee for this product. The cost is $105 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
3/23/2009 5:16:01 PM • Olympus Camedia... • Answered on Mar 23, 2009
Lost USB for Olympus Camedia C-480. Where can I buy a new one?
yes you can buy the new usb cable from canon store or you can try memory card reader
1/26/2009 4:21:49 AM • Olympus Camedia... • Answered on Jan 26, 2009
Trying to transfer images
The best solution is to obtain a card reader. Apart from anything else it will save a fortune on battery power. Are you connecting the camersa direct to computer or via a hub? and how many other USB devices are hooked up and running? All relevant- reduce these and see what hapens
6/17/2007 4:20:52 PM • Olympus Camedia... • Answered on Jun 17, 2007
2answers
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period. Always charge sets of batteries (2 or 4) together. Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set Don't use barrettes from different sets or brands together. I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away. Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad. Check you are using a charger for NiMH batteries. I would try another set (new) because buying Alkaline is also not cheap. I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger. Never use manganese (Zinc-Carbon) batteries in electronic devices. These batteries are only to be used in flash lights.
12/7/2016 8:12:01 AM • Olympus Camedia... • Answered on Dec 07, 2016
How to use zoom on c-860L
This 14 year old camera, does not have a zoom lens. It has a 5,5 mm lens, giving it a angle of view of about a 35 mm lens of a Full frame camera. However, you should be able to zoom digital 2 times. I can't find a manual, to help you on this, but the quality will be the same as cropping into a frame on your computer. So if you do put the pictures on a computer, you also can "zoom" in to the parts you want. Be aware a 1 megapixel camera, does not offer that much of detail.
10/27/2014 11:34:04 AM • Olympus Camedia... • Answered on Oct 27, 2014
Zoom error olympus
Lens is out of possition and stuck.
7/31/2014 7:19:31 PM • Olympus Camedia... • Answered on Jul 31, 2014
Camedia e20 problems
Put memory card into camera right way around.
7/5/2014 6:38:40 PM • Olympus Camedia... • Answered on Jul 05, 2014
Camedia e20 wont record picture
Hi, any error messages?
6/20/2014 1:31:49 AM • Olympus Camedia... • Answered on Jun 20, 2014
0answers
Olympus Camedia C-480 Zoom Digital Camera Logo
12 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
David Shaub
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
picture error appeared one photos
  • Cameras
