20 Most Recent Akai LCT2070 20 in. EDTV-Ready LCD Television Questions & Answers
Do a factory reset. To so this, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Akai LCT2070 20... | Answered on Jun 11, 2014
I think your color setting is not well. so plz check your color setting, if color setting is right. Then your color port has been damage. So change and repair.
If your are using external device check you cable connection & port.
Akai LCT2070 20... | Answered on Sep 12, 2012
Most universal AC adapters do not put out enough amperage, the Akai LCT2070 needs a 5amp 12v power supply. These adapters are available for $14 here:
http://www.ccl-la.com/catalog/product_info.php?products_id=48
Akai LCT2070 20... | Answered on Sep 09, 2012
You can buy a universal adapter from Best Buy or Radio Shack.
Here is a link to an Ebay seller that has the original, be advised I have never bought from them and cannot guarantee the reliability of the company.
http://stores.ebay.com.sg/LCDPAYLESS_W0QQcolZ4QQdirZQ2d1QQfsubZ0QQftidZ2QQpZ11QQtZkm
Let me know if this helps and please rate this solution. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
you can get these on ebay i know the power supplys are as cheap as 34 dollars. But the remote you can look for there to but i havent been successful finding one for mine probley cause i dont know what it looks like cause i bought this tv as a demo so they did not have a remote. Hope this helps.
Your power supply probably requires repair.
The power cord/adapter that you need is available here:
Hi.Please check the fuse of your television.Try to remove the back cover of the TV and find the fuse its located at the back of the board near the ac cord connection to the board then replace the same value of fuse.
Akai LCT2070 20... | Answered on Jul 05, 2011
The power cord is easy, radio shack or similar.
The remote is more of a problem, you could try a learning remote or see if there is one on ebay or akai
Please dont forget to vote if you liked my answer
thanks
Akai LCT2070 20... | Answered on Feb 11, 2011
If tv was working fine before and suddenly lost channels and not picking up channels in fresh channel scan then it seems problem with Tuner that got bad and become unable to decode channels.
Replace tuner board in tv, it is available in ShopJimmy.com
Click above link to view tuner board image and price info.
And if it is first time you are setting up channels scan in tv, make sure to select correct option of Antenna or Cable depending what is hooked in tv and start scanning channels.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Akai LCT2070 20... | Answered on Jan 14, 2011
You have to have factory remote to scan channels. Universial remote will not work.
Akai LCT2070 20... | Answered on Nov 30, 2010
most likely a defective power supply
Akai LCT2070 20... | Answered on May 28, 2010
You can get the ac adaptor on links below.
http://www.partselect.com/Search/PartsByModel/lct2070.htm
Also here is a link to an Ebay seller that has the original, be advised I have never bought from them and cannot guarantee the reliability of the company.
http://cgi.ebay.com.sg/12V-AC-power-adapter-for-AKAI-LCT2070-20in-LCD-TV_W0QQitemZ330393677399QQcmdZViewItemQQptZTelevisions?hash=item4cecff6e57
Akai LCT2070 20... | Answered on Apr 17, 2010
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Akai LCT2070 20... | Answered on Feb 25, 2010
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Akai LCT2070 20... | Answered on Feb 18, 2010
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Akai LCT2070 20... | Answered on Feb 16, 2010
Akai LCT2070 20 in. EDTV-Ready LCD Television Logo
54 questions posted
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Akai Televison & Video
Most Popular Question
image problem looks gray
  • Televison & Video
