20 Most Recent HP Pavilion DV5234US Notebook Laptop Questions & Answers
You are using a security protocol not compatible with the site's certificate. It depends on which browser you're using, but I have a few fixes in mind.
If you're using Internet Explorer: At the top go to Tools then Internet Options, then click on the tab that says Advanced. Scroll down through the list and you want to make sure that "Use SSL 3.0" is checked.
If you're using Firefox: At the top go to Tools, then Options. Then the tab that says Advanced. Click on the tab in the lower portion that says Encryption. Make sure "Use SSL 3.0" is selected.
If you're using Google Chrome: Uninstall and reinstall the newest version.
HP Pavilion... | Answered on Mar 12, 2018
That's a tough one. First, be prepared for the CD to be ruined. The process of getting it stuck or extracting it is likely to cause some significant scratches. If you can look into the drive and see the disc, try using some tweezers to work it out. Take your time - it's likely to be jammed up in there pretty good.
If you can't see the disc you may need to remove the drive and either attempt to disassemble it or just replace it altogether (the latter being my recommendation). If you look on the bottom of your laptop you should see a screw that is positioned on the centerline of the optical drive at what would be the back of the drive. It may even have a disc icon next to it. Power off, unplug it and remove the battery. Remove the screw then try pulling the optical drive straight out from the chassis. If you need leverage, use a paper clip to push the manual eject (behind the little hole in the front bezel of the drive) and use the drawer to -gently- pull on the drive. Replacement is just a matter of sliding the drive back in, seating it in the connector and replacing the screw.
If you opt to replace the drive you should be able to find compatible parts on eBay if you don't want to pay HP for an OEM part.
HP Pavilion... | Answered on Dec 09, 2013
when i want to open my facebook count it comes this message Erreur 107 (net::ERR_SSL_PROTOCOL_ERROR) : Erreur de protocole SSL pleasssssse help
HP Pavilion... | Answered on Jun 17, 2013
english please and be more specific
HP Pavilion... | Answered on Apr 17, 2013
No even if you did replace those few dios who to say that it will still work. It will cost you more money trying to fix this motherboard while you can replace it one time, and be finished with it. I would contact HP and order a replacement motherboard.
HP Pavilion... | Answered on Dec 18, 2012
try to change the network
HP Pavilion... | Answered on Oct 10, 2012
click start and then owner at top...or find in control panel
HP Pavilion... | Answered on Oct 07, 2012
Try updating your Adobe Flash software. You can get the latest version here:
http://www.adobe.com/support/flashplayer/downloads.html
HP Pavilion... | Answered on Jun 06, 2012
log on to roezer.com/LostBlog/error-neterr_ssl_protocol_error or www.techsupportforum.com
HP Pavilion... | Answered on Feb 12, 2011
click forgot password or click i can't acess my accounts... Answer some questions you provided during your registration
Hello manding, to restore any area dealing with the sound on your Computer; the same location will apply. First, click on the "Start Button," paul7of9_55.jpgin the (right pane) Control Panel, next in the category listings, select Hardware and Sound, paul7of9_56.jpg open and choose "Manage Sound Devices." The Sound window will open; paul7of9_54.jpg click the "Playback" button, paul7of9_57.jpg there should be a Speakers Icon, highlight to open, look below to find the "Properties button, paul7of9_58.jpg open the next window. There will be (4) four buttons "General, Level... first select the "General" button. Next, in the top of the window there will be a "Driver" button, paul7of9_59.jpg click on that button, select to "Update Driver." You can go back and "Tour the other areas, Speaker Level etc..." If you have a "MIC" do the same for the Microphone as you have done for (Speakers). Note: "Apply and OK all changes, to take effect. "Restart the computer to finalize the changes." I hope this information is helpful, thank you for using FixYa." paul70f9
HP Pavilion... | Answered on Jan 31, 2011
If you are using an email program, you don't have the protocol setup correctly. If you are trying with a web browser, you have another problem.
If you are using Google's Chromium. I don't know of a fix except to use another web browser and set it to Classic mode. Now Google's Chromium should work.
HP Pavilion... | Answered on Jan 28, 2011
Have the HP check the video card driver. having a plain white screen with no icons or wallpaper means there's something wrong with the video card driver or the hardware itself.
HP Pavilion... | Answered on Dec 30, 2010
http://www.roezer.com/LostBlog/error-neterr_ssl_protocol_error/
HP Pavilion... | Answered on Dec 04, 2010
Sorry to said but there are no drivers for your notebook for Windows 7. I suggest you to download from this link previous drivers and use these drivers at your notebook in compatibility mode. This means that before the drivers installation, right click on the installation file, choose properties - compatibility and check compatibility with the version of the drivers you download. For example if you download the drivers for Vista check the Vista compatibility. Note that the Vista drivers are available for 64bit also.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
HP Pavilion... | Answered on Nov 03, 2010
25 character product key home and student office 2007?
HP Pavilion... | Answered on Oct 18, 2010
Are you using Internet Explorer or Mozilla Firefox ?
Open Internet Explorer
Click on TOOLS option from menu bar on top ( or Ranch like icon on right side on tool bar )
Click on INTERNET OPTIONS
In the General Tab - Under Browsing History you will find - Delete Button.
Click on the button and click on Delete all button below.
put check mark on the option : Also delete files and settings stored by add-ons. and click Yes.
It will go thru the process of deleting the unwanted files and webpages and other data stored on your pc that is blocking the net access to browse.
Close the Internet Options and close Internet Explorer and try to open your website. Tt should work
For Firefox
Click on TOOLS ( from menu bar
Click on OPTIONS
Click on PRIVACY TAB on top
Choose the option - Clear all Current History. Click Apply Button
Click on ADVANCE TAB on top and Click on RESTORE Factory Defaults - Click Apply
Click OK
and try to browse
Also Click on START button
Type " %temp% " and hit enter ( without " quotes " )
Select all the files shows in this folder and delete them.
These are temporary files and folders and you can delete them without causing any problem to your pc.
This helps run your PC faster too
Try to launch yahoo and it should open. your issue should be resolved.
HP Pavilion... | Answered on Sep 21, 2010
HP Pavilion DV5234US Notebook Laptop Logo
Popular Tags
154 questions posted
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
error 107 net err ssl protocol error
  • Computers & Internet
