20 Most Recent
Brother MFC-3360C All-In-One InkJet Printer Questions & Answers
I have a Brother MFC-3360C printer and have an error. Clean Unable 51
Error 51 normally indicates a paper jam or a sensor problem. Check the paper path and the printer head movement zones (far left and right) for any foreign objects (even small pieces of paper). If there has been a paper jam, was the paper forcibly removed? If so, possibly one of the sensors has been knocked out of position or damaged. Dust, dirt, grease or spilled ink may also be contaminating a sensor. This is maybe one of the most elusive problems to solve..!
4/14/2015 5:38:01 AM •
Brother...
Answered
on Apr 14, 2015
Brother printer MFC-3360c working for years now it
Most likely the soldered-on fuse on the circuit board has blown. Check online for information on how to replace this or contact Brother Support for instructions. I have found that the prices on the replacement parts through the manufacturer is very price competitive and their staff helpful.
10/23/2013 5:04:10 AM •
Brother...
Answered
on Oct 23, 2013
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
10/14/2013 11:28:14 AM •
Brother...
Answered
on Oct 14, 2013
My Brother MFC-3360C has worked perfectly until I
First I will have to recommend that you leave the unit connected directly into your computer rather then through the USB hub.
You will also want to reset the printer.
1. Turn the power off by unplugging the cable.
2. Hold down the Menu button
3. Plug the power back in while holding menu
4 You should see "maintenance" on the screen; if you do not repeat steps 1-3.
5. Press 0 1
6. Once you return to Maintenance, press 9 9
If this still does not work you will want to uninstall and reinstall the software.
Thanks,
Pat
1/21/2013 3:12:59 PM •
Brother...
Answered
on Jan 21, 2013
Black cartiage is not working
Sir,
Check the black cartridge it will refill or not? open the black cartridge and shake it and reinsert. Check with printer options, if any option selected with color only uncheck it and select the best quality option.
Thanks
Good Luck
11/5/2012 5:58:09 AM •
Brother...
Answered
on Nov 05, 2012
Why does my printer not print
Ink cartrage could be installed inproperly..the machine Must be close and latched properly also. p.s. Make sure the safty tab is removed from the new cartrage.
6/7/2012 3:30:12 AM •
Brother...
Answered
on Jun 07, 2012
