20 Most Recent Canon imageCLASS MF3240 All-In-One Laser Printer Questions & Answers
what makes it to show please wait and the solution to it.
Canon imageCLASS... | Answered on Apr 28, 2016
Possible the toner is got damaged while removing it with the printer and replace it with the new one.
Canon imageCLASS... | Answered on Jan 02, 2013
Go into printers and faxes in Xp or Printers and devices in Windows 7. Double click on the printer icon and click on file and then Offline and it will change to online. That should do it.
Canon imageCLASS... | Answered on Apr 12, 2012
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload : -http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Canon imageCLASS... | Answered on Mar 28, 2012
Hello Lea! Welcome to FixYa!
If your printer prints wrinkled pages then first of all it may be because of paper jam or paper tray, their may be a small sheet of paper remain inside causing problem or the paper tray is not properly inserted, So check there must not be any piece of paper or if paper tray is not properly inserted, Insert it correctly.
If problem is still there then this problem is usually caused by the Fuser assembly or Tension Roller of the printer. You need to change the tension roller of the printer and if need then change the Fuser Assembly. My advise is as it is technical hardware problem so you must consult with Canon Authorized Center and they will replace the roller of the printer and if there will be need they will change the Fuser Assembly of your Canon image Class MF3240 printer
I hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Canon imageCLASS... | Answered on Mar 04, 2012
try this
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Also open the back cover of the printer if this model has one.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Canon imageCLASS... | Answered on Jun 18, 2011
The grey film is whats left of your fuser. you need to get a new fuser sleeve or a new fuser. Thank you, Steven 818-888-0006
Canon imageCLASS... | Answered on Oct 05, 2010
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Canon imageCLASS... | Answered on Aug 23, 2010
Hello there,
Hope I could still share with you this fix because this is where you need to look at when you think you have done everything to remove the paper jam.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
You can also click on this link for this trick.
http://www.fixya.com/support/r3827902-canon_imageclass_mf3240_paper_jam_fix
Canon imageCLASS... | Answered on Jan 09, 2010
If it's not throwing an error code, you'd have to have a tech look at it if it's worth the cost of repairs. My guess is no; it's usually cheaper to replace these cheapo printers.
Canon imageCLASS... | Answered on Sep 10, 2009
The problem is with the DC controller board, either bad connection or bad board.
Canon imageCLASS... | Answered on Jan 10, 2020
I guess youve tried switching it off and on?
If so It needs its system software reloading. Only Canon reps can get hold of this, best to get someone locally.
Canon imageCLASS... | Answered on Nov 17, 2019
Canon imageCLASS  MF3240 All-In-One Laser Printer Logo
25 questions posted
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
imageCLASS Canon
  • imageCLASS Canon
Most Popular Question
blicking light canon d480
  • Office Equipment & Supplies
