20 Most Recent Nikon D70S Digital Camera with AF 28-80mm f/3.3-5.6G Lens Questions & Answers
if the line came in photos when you seen them from PC then its a Camera CCD fault, Or If the photo clear in PC view then its a LCD fault.
Nikon D70S... | Answered on Aug 05, 2012
The number after the "r" tells you how many more pictures you can shoot in the current burst before the buffer fills up and the camera has to slow down. If you're only taking single shots or short bursts then it shouldn't affect your shooting at all.
Nikon D70S... | Answered on Oct 30, 2011
If flash pops up and doesn't fire, little white pin/lever inside flash has lodged up inside and needs to be eased from where it is stuck.  Careful when opening the flash up to dislodge the white plastic pin/lever, there are tiny wires you REALLY don't want to damage....
Nikon D70S... | Answered on Mar 11, 2010
Is the camera in airplane or power saving mode?
Nikon D Cameras | Answered on Feb 02, 2019
By not clear do you mean out of focus or streaked due to movement? Try using a higher ISO setting in order to allow for a faster shutter speed and/or use a tripod.
Nikon D Cameras | Answered on Aug 02, 2018
switch button got damage due to hard press so you need to replace it
Nikon D Cameras | Answered on Aug 24, 2017
You can use the Nikon View program that should have been included with the camera. or you download the current versions of Nikon ViewNX or Nikon Capture available free at Nikon Imaging Products Software
Nikon D Cameras | Answered on Dec 11, 2016
Have you tried to see if you camera is running the latest firmware? If its not update it.
Nikon D Cameras | Answered on Jul 02, 2016
You could probably use either a 1.4 x or a 2 x, depending on how much you wanted to increase the focal length of your lens. A 1.4 x would give you a range of 98-420, a 2 x would give you a range of 140-600.
Having said that, teleconverters are not usually recommended for use with zoom lenses, and you would lose one stop with the 1.4 x, two stops with the 2 x, thus necessitating longer exposures. Also, with the increase in focal length comes an increased probability of camera shake being more apparent, due to the increased magnification. In your position, I would attempt to get closer to the subject, using a teleconverter as a last resort if this is not possible.
Nikon D Cameras | Answered on Jun 08, 2016
Format the SD card first.
Nikon D Cameras | Answered on Apr 17, 2016
Go to Nikon website for manual download.
Nikon D Cameras | Answered on Mar 27, 2016
hi,
did you charge your battery full ? if the battery is not charged enough, it will not drive the shutter opener motor perfectly, and if any type of dirt or friction on the shutter drive gears this will happen, please check the shutter movement by removing the lens.
Nikon D Cameras | Answered on Mar 03, 2016
You need send your camera to service, your zoom lens stuck.
Nikon D Cameras | Answered on Dec 04, 2015
I use GIMP 2, a free open source editor that is very sophisticated.
I think I had to install an add-on so that it would read NEF files. Gimp converts all files that are edited in it to its own "xtg" file extensions. After I finish editing, I save the picture in the "xtg" file extension then I import it in "jpg" format to the same folder where the original NEF along with the XTG formats are stored. During the editing process, I usually scale the image if I plan to send it somewhere on the web.
I think a lot of other editors have a similar function, especially if the proper codecs are installed.
In addition, in the past I have used conversion programs to do the same thing but it's been a long time. Do a web search for NEF converters and you may come up with a free program or two that will allow you to make the conversion without editing the picture.
Nikon D Cameras | Answered on Oct 09, 2015
Not sure, but if you shoot in manual mode and use manual focus the camera should still take photos. Kind of defeats the purpose of spending money on auto focus ones though. Try to turn the top dial on the camer to M (manual) see what happens?
Nikon D Cameras | Answered on Feb 02, 2015
To copy your pictures, jpg or NEF (RAW) to your computer, you first must install the ViewNX2 software that came with the camera (on a CD) or get the software for free from the Nikon website.
Fitst install the software, then connect the camera with an USB cable then switch the camera on.
Current versions of Nikon software Nikon Knowledgebase
Nikon D Cameras | Answered on Jan 11, 2015
If you managed to press the lightening cable form a iPhone 5(s) or 6 into the camera's mini USB connector, you must have broken the connector. I wonder if a repair is worth paying for, because the D60 is not that expensive second hand and a repair could cost over 200 dollar.
If you pressed the plug into the connector, some plastic parts must have come out, making it possible the metal contacts created a shortage. (Your battery will be empty by now) I can't advice you to do what to do, but I can describe what I would try if I had the same problem. First I would remove the battery, because some USB contacts could be connected to the battery. Don't make a shortage while the battery is still in.
Under a loupe with a bright light, I would try to pull out the plastic from the connector. Then check if and where a shortage is. I would try to undo the shortage and isolate the pins. Only then I would try to switch on the camera again, knowing I never could use the USB port again. If the camera would again switch on, I would again switch it off and remove the battery. Then taking care I would isolate all contacts forever, perhaps with some 2 component glue. Carfull not to connect points again. For transferring pictures I should use an external memory card reader and keeping the USB port closed forever.
It is a pity I don't have the D60 manual,because in the D50 the side where the USB connector is, is easy to remove, so you could even remove the connector from the camera, or disconnect it from the circuit board.
Everything hypothetical and don't blame me, if your camera never will work again.
I checked on iFixit, but they did not started a repair guide yet.
Nikon D60 Repair
Nikon D Cameras | Answered on Dec 17, 2014
Nikon D70S Digital Camera with AF 28-80mm f/3.3-5.6G Lens Logo
4 questions posted
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
D Nikon
  • D Nikon
Most Popular Question
line appearing from center view finder
  • Cameras
