20 Most Recent Samsung SCX-4521FG All-In-One Laser Printer Questions & Answers
how to solv scx-4521 out of range
Samsung... | Answered on Jan 30, 2019
display indicate any error message?
scanner is normal but i think the cartridge is not recognize?
check your cartridge
Samsung... | Answered on Nov 10, 2016
aap ka free diver kis site par milegi -----samsung scx4521f
Samsung... | Answered on Dec 09, 2013
Hello David kayombo,
Your SCX-4521FG is low on toner, or you need to take the toner out shake it and then place it back in machine.
Samsung... | Answered on Aug 22, 2013
pls refix your printer cartige & clean the contacts between printer & cartige.
Samsung... | Answered on Jan 24, 2013
I only answer through this site, sorry for th inconveniences. There is a troubleshooting that can be done, but I need confirmation that you will read this message.
Samsung... | Answered on Aug 10, 2012
It is possible but the recommendation is not to refill but use the OE cartridge so as to continue with the warranty and full life of the printer.
Samsung... | Answered on Jun 29, 2012
I recommend calling Samsung about this problem
Samsung... | Answered on Jan 14, 2011
The surface (drum part) of the toner cartridge inside the machine has probably been scratched.
Remove the toner cartridge and install a new one.
If the problem persists, call for service.
The toner cartridge may be defective.
Samsung... | Answered on Dec 21, 2010
if toner is low display toner low
copy counter press menu goto the report and system data
Samsung... | Answered on Jun 17, 2010
your quest is not completed........
what is printing.... your last printed work... or any other..
pls.give a detailed information.
Samsung... | Answered on Apr 29, 2010
Are you getting a blank page out? Then your document may be upside down (it needs to be face down on the glass or face up in the ADF). If you are not getting any output but get an insufficient memory error, you may not have enough memory available for the chosen resolution. Try using the prescan feature and adjust your resolution to a lower one.
Is the light coming on and the scanner imaging system moving? Does scanning work from your computer? Since this all-in-one doesn't appear to have a scanner lock (to protect it during travel), the machine may need professional maintenance from Samsung.
I hope this helps.
Samsung... | Answered on Mar 19, 2010
The driver files are here.
The software files are here.
Download the driver/software that corresponds to your OS from the link.
Samsung... | Answered on Feb 26, 2010
Hi ,
Price
in the Range: $261.00 to $269.00.
Samsung... | Answered on Dec 30, 2009
A lot of times, you can use google and search the exact problem and printer model number, I just had a similar problem with Windows, you may need to update a driver.
Samsung... | Answered on Oct 13, 2009
please you service your copier laser unite.
clear your copier cartridge wast toner unite
or setting toner save mode if you are saw on setting off
thanks
Tareq
Samsung... | Answered on Aug 26, 2009
Follow these steps to refill the toner
1.First, locate (or make) a fill hole
2.Second, fill the cartridge with the right toner.
3.Third, reseal the fill hole
Thanks!
mannu_rakesh
Samsung... | Answered on Aug 24, 2009
do you refill right Samsun ink,if that true,clean ink blake.
Samsung... | Answered on Aug 01, 2009
probally the drum, it is inside the toner cartridge. is it a mfg toner,refilled or maybe aftermarket? these aftermarket ones don't always work. it could be a transfer corona problem but the three lines lead me to the toner drum
Samsung... | Answered on Jul 09, 2009
there are sensors that tell the machine the paper is jammed us a q-tip to clean them, remove the toner cartridge and check under that area when cleaning the sensors.
Samsung... | Answered on Mar 16, 2009
Samsung SCX-4521FG All-In-One Laser Printer Logo
Popular Tags
28 questions posted
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
SCX Samsung
  • SCX Samsung
Most Popular Question
printer samsung printing without stop
  • Office Equipment & Supplies
