20 Most Recent
Philips 50MF231D 50 in. Plasma Television Questions & Answers
TV would not power up. Just replaced 2 blown caps
if you are using the TV with a cable receiver, connect the TV to a DVD player, make sure all volume are turned on and observe if the TV will bring an sound.
If you don't hear any sound, then it means the audio chip/sound IC is defective, or maybe it has been tampered with unknowingly, when fixing the power problem.
Again, one way to confirm if actually, the audio chip/sound IC is the cause of the problem, connect a earphone to the TV headset part and if you do not hear any sound, then it means the audio chip/sound IC is the cause of the problem.
So, cross check the audio chip/sound IC, read it with a meter to know if it's defective. If its defective, make necessary replacement, just like you need when replacing the 2 blown caps on the power suppl board of your TV.
I hope this helps.
Good luck.
How do i fix my magnavox tv, it keeps blinking
If you remove the back, you might see a couple of electrolytic caps that are bulged on the power supply, that need to be replace, or just replace the power supply itself. There are also two readings, that you can read, the VA voltage and The VS voltage. There will be a label on the inside on the back farme that will tell you what the VS, VA, voltages should read on the output of the power supply.
Wont turn on
Take the back off of the TV and look at the power supply board (middle of the set). One or more electrolitic capacitors will have the tops swelled up. Replace them with the same value parts and you will be OK.
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
gysgt2u1@yahoo
Remote suddenly desn't work
you may have accidentally pressed one of the wrong button at the bottom of the remote control. the codes are in the back of the user manual
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
