20 Most Recent Amana ARSE67RBS Side by Side Refrigerator Questions & Answers
How to run off the ice maker
if you want to turn off the ice maker just lift up the lever up on the ice bucket that releases the ice an leave it there an when you want to start the ice machine again just release it back down
12/22/2012 5:14:39 AM • Amana ARSE67RBS... • Answered on Dec 22, 2012
Have ice crystals in freezer
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
For
extra help go here:
Thanks
for using fixya
Leo Ponder
imufo2
8/19/2011 3:47:33 PM • Amana ARSE67RBS... • Answered on Aug 19, 2011
The top half of both the freezer and refrigirator
Its not likely that you disconnected anything. If you did it would be obviouse by a wire being loose or hanging out in the open unplug the fridge before poking around though. The frost points to a possible problem you could have a ice block in the back. Does the fan in the fzr run? If not your unit could have a defrost timer under the bottom where you cleaned it and you unplugged it. Usually newer fridges have the defrost timer in the top of the fridge side. If the fan is running the next thing to ask is if the compressor is running if not the compressor starter may be bad it is located under the plastic cap on the compressor and is about the size of a nickel and will be hooked to one of the 3 prongs of the compressor its a cheap part. If he compressor is running your heating element (defrost element) in the fzr compartment may be bad it is located where it is in contact with the cooling coils in the fzr compartment usually behind the back wall of the fzr. It can be testedwith a ohm meter and will be a long black or glass part. Attached to one end of the heating element is a limit switch it a round pastic and metal sensor apx the size of a quarter with two wires one goes to the defrost element. Its job is to limit the heat so it melts ice but does not heat the fzr up. I hope this helps good luck and remember to unplug the fridge and be safe.
8/13/2010 1:13:30 PM • Amana ARSE67RBS... • Answered on Aug 13, 2010
Where do I find the water filter on a Amana
here is a breakdown of the location of the water filter on your fridge. hope it helps. 67002378 is the part number for the filter.250
11/9/2009 3:14:16 AM • Amana ARSE67RBS... • Answered on Nov 09, 2009
Amana SXD2252 side by side ice maker stopped, now leak on floor
ck here... https://www.appliancepartspros.com/repair-help/amana-refrigerator-sxd22s2w-repair/sxd22s2w-leaking.html But before throwing parts at it give their tech 877# a hollar.. Best to you
9/4/2023 5:56:53 PM • Amana... • Answered on Sep 04, 2023
Amana ARB1917CSR 18.5 Cu. Ft. Plus Refrigerator. What is the HP of my compressor, which Supco relay and run capacitor?
What tends to happen is that service techs have certain common generic parts in their van, and rather than ordering a part to fit and have a return visit, they fit what they have. Parts seem to be readily available. The compressor is listed but no HP Specs. The bottom show another model and that R134A (1/4HP) is different to R134 (1/5 HP). https://www.google.com/search?q=amana+arb1917csr+parts+diagram https://www.google.com/search?q=Tecumseh+TP122AR003B8 ..
7/27/2023 6:43:23 PM • Amana... • Answered on Jul 27, 2023
3answers
Need to find water filter on my amana model
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
6/20/2023 3:26:22 PM • Amana... • Answered on Jun 20, 2023
Possible cause of Amana refrigerator making a constant clicking/noise?
Sharla, It could possibly be the ice maker rod that tells the ice maker whether it's full or not. If it's in the down position it wants to make ice and it'll make a clicking noise. Lift the rod up if it's down. Hopefully this helps!? Best to you.
4/21/2023 7:28:31 PM • Amana... • Answered on Apr 21, 2023
3answers
What year is my Amana refrigerator, Model # ASD2522WRB06?
I'd like to know how you determine the age based on the info inside my Amana. I double checked the numbers. Model AFI2538AEB4 Serial KY2886165
3/4/2023 11:22:10 PM • Amana... • Answered on Mar 04, 2023
Afd2535des not cooling in any department, when I opened the doors, the lights work and the led temp control lights up. I hear a fan start and 5 seconds later the fan stops n leds shut off.
  1. Check the thermostat: Make sure the thermostat is set to a temperature that is low enough to cool the refrigerator. If the thermostat is not working properly, it may need to be replaced.
  2. Check the condenser coils: The condenser coils on the back of the refrigerator should be clean and free of dust and debris. If the coils are dirty, the refrigerator will not be able to cool properly. Use a vacuum cleaner or a brush to clean the coils.
  3. Check the fan motor: If the fan motor is not running, the refrigerator will not be able to cool properly. Check if the fan motor is receiving power and if it's spinning freely. If the fan motor is faulty, it will need to be replaced.
  4. Check the start relay: The start relay helps the compressor start up. If the start relay is faulty, the compressor may not start and the refrigerator will not be able to cool properly. If the start relay is faulty, it will need to be replaced.
  5. Check the compressor: If the compressor is not working, the refrigerator will not be able to cool properly. Check if the compressor is receiving power and if it's running. If the compressor is faulty, it will need to be replaced.
2/16/2023 2:42:10 AM • Amana... • Answered on Feb 16, 2023
No power to Amana ice and water dispenser. Rest of refer runs fine.
It's possible that the issue could be with a micro switch located on the ice maker cabinet that is activated when the prong on the back of the ice/auger tray is inserted. It's also possible that there could be another issue with the dispenser, such as a problem with the wiring or a malfunctioning component. I would recommend checking the wiring and testing any other micro switches or components that are related to the dispenser to see if they are functioning properly. If you are unsure how to do this, I would recommend consulting the user manual or contacting a qualified technician for further assistance.
1/14/2023 10:27:43 AM • Amana... • Answered on Jan 14, 2023
Where is the defrost timer located in Amanda Model SXD2252W
check to see if defrost fan working
10/19/2022 2:58:33 AM • Amana... • Answered on Oct 19, 2022
How do you remove the light cover from amana refrigerator model arb2107?
I have an Amana AS12575GRB01, the cover to the light bulb on the fridge side is mounted on the top inside back right corner. Having problems removing it
9/8/2022 1:07:18 PM • Amana... • Answered on Sep 08, 2022
I have an Amana Fridge (model ABD2533DEW) that makes a buzzing noise for about 10-12 seconds and then clicks off.
There are several videos on line about buzzzing fridges. This is one https://www.youtube.com/watch?v=O2TVZazGLJ0
6/29/2022 2:41:17 PM • Amana... • Answered on Jun 29, 2022
2answers
Refrigerator not cold and have
4/9/2022 3:40:32 AM • Amana... • Answered on Apr 09, 2022
3answers
How do I remove the factory installed Amana household refrigerator for repair?
Hello, Stephen -I am not finding relevant information for you. I do not own an Alpenlite Fifth Wheel RV myself.I suspect you will receive relevant instructions from another owner. For that, if you have not already posted your question on an online RV discussion forum, I suggest you do so. These are links to some forums. Registration is required for each, but they are all free:iRV2:http://www.irv2.com/forums/f104/alpenlite-5ers-125073.htmlRV.net:http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/22871819.cfmRVNetwork:http://www.rvnetwork.com/Technical Tips & Tricks is probably the best category for your refrigerator question.RVTalk.com (RVUSA):http://www.rvtalk.com/Both the RV Tips & Tricks and the Towables category would be the best for you to post your question.Best wishes
1/13/2022 5:29:47 PM • Amana... • Answered on Jan 13, 2022
I need a wiring diagram for hooking up the wires from the dispenser control board on facia of a Amana ARS2664bBW refrigerator
Contact Amana directly to request the wiring diagram.
8/20/2021 8:28:56 AM • Amana... • Answered on Aug 20, 2021
Amana ARSE67RBS Side by Side Refrigerator Logo
7 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
run off ice maker
  • Refrigerators
