20 Most Recent
Initial HDTV-322 32 in. LCD Television Questions & Answers
Fix my sound
Are you just watching normal TV? May need more information. If you're watching cable etc.. check the volume on that device.
No input signal hdmi
Make sure the HDMI connection is secure. Madke sure it is on the correct input. Turn on the peripheral first, i.e. dvd, cable box, etc. then turn on the tv. If you still have problems, test whether or not the HDMI cable is bad by trying with another device. If okay, make sure the device or peripheral works with a different type cable. Try to change the inputs from HDMI input 1 to say HDMI input 2, etc. If you can't get HDMI to work just switch it to component. HDMI video is not Superior to component it just affords one to have true 5.1 surround sound broadcast.
When i turn it on
you have to check on system regulator and main Program ( EEPROM),you should check parts, such as: elco, zener diodes, and transistors and final IC program, you have to check 5 Volts = VDD from the power regulator IC EEPROM, there must be an incoming voltage available to drive power on the entire circuit TV.
DVD Player not working 32" Initial HDTV built-in DVD
Hi,i think that is the laser lens is dirty
try to clean it ,with a long q tips an alcool, unplug the set before doing so, it solved the problem usely.
but it can be the laser assembly and he will have to be replace no alignement needs...
hope that will help you
regards A.S.
None of the buttons on teh buttons on the
Unfortunately, both the local controls and the remote are controlling an integrated circuit on the main board that does the actual work.
I think you can expect to have the main board replaced or exchanged and this won't be cheap if available at all.
I think this company is related to the infamous 'Ilo' that was once sold by Mall-wart.
They were bankrupt but the leftovers may still be available.
Universal remote
It seems after months of looking the code for this remote, I have had no luck, so I bought a universal remote that "learns" from the original remote. That is the only way that I have been able to solve this problem.
Remote control
Is this a new condition?
Or has it operated differently in the past?
If you are connected to any kind of box (satellite for example), there is only one channel that the TV sees; usually 3 or 4.
The channel changes are limited to the box.
