20 Most Recent Philips 37MF321D 37 in. LCD Television Questions & Answers
I just fixed a similar problem on mine but the power light was flashing at the same time the screen was flashing. I made a video showing what part and how to replace it. I also added a link to the part I ordered. L5973D STMicroelectronics Mouser
Philips 37MF321D... | Answered on Jan 24, 2016
Just fixed that exact problem on mine and made a video on what part and how to replace it. I also added a link below for the part I bought. L5973D STMicroelectronics Mouser
I fixed that exact problem on mine and I made a video on how I found the bad part and how to replace it. I also added a link to the part I replaced below. L5973D STMicroelectronics Mouser
Hey Superdave,
Does the whole tv turns off when the picture turns off ??? What you're describing sound like a defective CCFL backlight. This would make since why someone threw it out because the repair estimates of replacing the bulbs would knock your socks off. Most will suggest ordering a new LCD panel assembly which would cost way more than what the set is worth. On some sets, when a CCFL is out, the screen will come on for a few seconds then go out. On other sets, after so many "lamp failures" logged in memory, the set will not power up at all and just flash trouble codes through the power indicator.
Philips 37MF321D... | Answered on May 12, 2012
Good thinking as these sets have lots of issues--sounds like a loose connection somewhere if intermittent could be hard to locate.
Philips 37MF321D... | Answered on Apr 03, 2012
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress from www.shopjimmy.com.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Philips 37MF321D... | Answered on Sep 27, 2011
solution
Step 1 :At fast check your speaker.
Step 2 :
Test the ON/OFF volume switch.
Step 3 :Test audio IC for pcb.
Philips 37MF321D... | Answered on Jul 16, 2011
Hello
I actually don't understand what you mean by this question. About which capacitor do you mention about? For which section of your TV you want the capacitor? There are so many capacitors used in different sections, and have different capacitance values, and in idfferent voltage ratings. Without knowing the section, I can't give you advice to this post. Reply with details by Fixya please.
Philips 37MF321D... | Answered on Feb 26, 2011
as you tell your tv problem its look like need to replaced lcd panel.for confirm please send picture of your problem.
Philips 37MF321D... | Answered on Oct 18, 2010
Sounds like you need to repair the power supply, don't fret, it can be really easy. Here is a pair of youtube videos I made after following some advice on this website from other posters:
http://www.youtube.com/watch?v=qSS6ycUxS98
http://www.youtube.com/watch?v=oTOkHKPJsnM
Philips 37MF321D... | Answered on Sep 02, 2010
Power supply board is bad.
Inspect for damaged electrolytic capacitors on the power supply board.
Philips 37MF321D... | Answered on Aug 11, 2010
in the lcd tv there are three main parts
1)the inverter board(pannel)
2)the main board .
3)the power supply board.
if there is no power at all them main board is faulty.if no front led light is coming ON there is no power .so the main board is faulty.on the main board there is a fuse located you have to replace that and check first if still no power main board needs to be checked and replaced
if there is sound but no picture and front led light is ON then its inverter board panel problem.if this is your case replace inverter panel.its located in the lower side of the lcd in the inner area below the main board.
but if there is just front led light blinking , but no picture or sound then its power supply board problem.
but as you mentioned that the tv turns ON for some seconds then automatically turns off this indicates that the power supply board is not faulty but there is a component on the board that is getting over heated because its got weak so due this overheating of a component the circuit gets short and tv shuts off.
on power supply board there are some capacitors and ic located.if any of the component gets short or budged up then it short the power supply board.so you can check the components on power supply board with multimeter and get it replaced by using soldering iron.
also you can get new replaCEment power supply board.this clears the problem completely.
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Philips 37MF321D... | Answered on Feb 20, 2010
This is a big problem with these tv's. Magnavox built them with undersized capacitors, and they blow. You have to open the back, remove the power supply and replace the capacitors numbered 2074 and 2081. This sounds like a real tech job, but read my other solutions, and you will see it is not so hard. Good luck.
Philips 37MF321D... | Answered on Sep 30, 2009
I had the same problem. Take the back off the TV.....disconnect power supply first....
You probably will find a cooling fan on the right side that is froze up. Get a Strong vacuum, clean it until it turns freely. The TV will now work unless you have other problems.
Philips 37MF321D... | Answered on Apr 01, 2009
Philips 37MF321D 37 in. LCD Television Logo
36 questions posted
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
im having problem philips 37 in lcd tv
  • Televison & Video
