20 Most Recent
Leica DISTO D330i Questions & Answers
Leica Disto A5 does not measure with the main button, but it does measure with the timer
It's possible that the main button may be malfunctioning or broken, which is preventing it from activating the laser. Here are a few troubleshooting steps you can try:
- Ensure that the laser is not obstructed or dirty. Use a soft, dry cloth to wipe the lens clean.
- Check the battery contacts and make sure they are clean and properly aligned. You can clean the contacts with a cotton swab and rubbing alcohol.
- Try resetting the device by removing the batteries for a few minutes and then reinserting them.
- Check the user manual or manufacturer's website for any firmware updates that may address the issue.
If none of these steps work, it may be necessary to send the device in for repairs or contact Leica customer support for further assistance.
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
How can I adjust the time on my weather station model #sgr72914?
- Access the Time Setting Mode:
- Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
- Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
- Adjust Hour and Minutes:
- Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
- After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
- Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
- Confirm the Time:
- Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
- Check the Time Display:
- After setting the time, check the display to ensure that the time is displayed correctly.
