20 Most Recent Pelican Products 9460 - Products 9460-Y Remote Area Lighting System, Yellow Questions & Answers
Contact LaCrosse direct. We are FIXYA dot com
Wireless Thermometer - La Crosse Technology
www.lacrossetechnology.com > media > catalog > product
PDF This Wireless Thermometer features: indoor/outdoor temperature with MIN/MAX readings in Fahrenheit or Celsius, outdoor temperature trend arrow, and manual ...
Measuring Tools... | Answered on May 07, 2020
First, insert the new batteries into the Temperature sensor. (see "Install and replace batteries in the Temperature sensor").
2.
Immediately after and within 30 seconds, insert the batteries into Weather station (see "Install
and replace batteries in the Weather station"). Once the batteries are in place, all segments of
the LCD will light up briefly. Following the time as 12:00 and the "Weather man" icon will be
displayed. If these are not displayed after 60 seconds, remove the batteries and wait for at least
10 seconds before reinserting them.
3.
After inserting the batteries, the Weather station will start receiving data from the sensor. The
outdoor temperature and the signal reception icon should then be displayed on the Weather
station. If this does not happen after 3 minutes, the batteries will need to be removed from both
units and reset from step 1.
4.
In order to ensure sufficient 915 MHz transmission however, this should under good conditions
be a distance no more than 100 meters between the final position of the Weather Station and the
sensor (see notes on "Mounting" and "915 MHz Reception").
Note:
If the signal reception is not successful on the first frequency (915MHz) for 45 seconds, the
frequency is changed to 920MHz and the learning is tried another 45 seconds. If still not....
and about the Sad Face
Comfortable:A happy face icon "(68°F to 78.6°F)and relative humidity reading between 45% and 65%.Uncomfortable:A sad face icon " " indicating any value outside the comfortable range
https://www.manualslib.com/manual/516303/La-Crosse-Technology-Ws-9630u-It-Ca.html?page=7#manual
Measuring Tools... | Answered on Apr 29, 2020
Reset display by pressing the RESET button, located on the back of the display unit inside the battery compartment. Date and time will need to be entered after a reset. Flashing of the outdoor temperature is generally an indication of wireless interference.
https://www.acurite.com/media/manuals/00754-instructions.pdf
Hard Reset:
  1. Bring both the sensor and display unit together and power down by removing at least one battery from each and/or removing the power cord.
  2. Make sure the A-B-C switch on both units matches. ...
  3. Reinstall the battery in the outdoor sensor.
  4. Reinstall batteries and/or power cord into the display unit
https://support.acurite.com/hc/en-us/articles/360013641694-3-in-1-Reset
You may use following removals Tools
  • Moving Dollies
  • Pallet jacks
  • Hand Trucks
  • Hydraulic Tools
You may also get information about Removals Tools Here
Removal Companies Tools
Measuring Tools... | Answered on Apr 24, 2020
https://support.acurite.com/hc/en-us/articles/360007555574-Temperature-is-Flashing-Stuck-or-Showing-Dashes-on-a-Basic-Multi-Sensor-Display-
Measuring Tools... | Answered on Apr 22, 2020
Take it apart and get some isopropyl alcohol and a q-tip. check for corrosion around the terminals. If there is none, look for loose connections. If there is something loose, check if a bit of the board is loose. If a bit of the board is stuck to the terminals, give up on batteries.
I do not believe that you can buy these separately. They are factory programmed and paired together.
Measuring Tools... | Answered on Apr 09, 2020
Your local Culligan dealer is the only place to get one. You need the retrofit kit to prevent the shaft of sealpack from bending.
RJ
Measuring Tools... | Answered on Mar 19, 2020
Change the batteries on both units. The home station often has a good display, but not enough power to communicate. I buy CR2032 in packs of 10!
Measuring Tools... | Answered on Mar 15, 2020
https://images.homedepot-static.com/catalog/pdfimages/c6/c6dfd8a3-256c-4785-a1b5-f845723b06e2.pdf
Measuring Tools... | Answered on Feb 28, 2020
If this is the Smart Electrician Non-Contact Voltage Tester (or similar)...then pull off the rear black piece
Measuring Tools... | Answered on Jan 18, 2020
A Geiger counter is a device for measuring radioactivity by detecting and counting ionizing particles.
Measuring Tools... | Answered on Jan 13, 2020
Pelican Products 9460 - Products 9460-Y Remote Area Lighting System, Yellow Logo
0 questions posted
Top Pelican Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Pelican Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Pelican Measuring Tools & Sensors
Most Popular Question
outdoor temp thermometer transmitter
  • Measuring Tools & Sensors
