20 Most Recent
Brookstone TinyTunes MP3 Player Questions & Answers
No user manual; can't operate it.
What is the model number of your Tiny Tunes. I think it will be easier for us to find the user manual (if there's available) if we have the model number of your player.
Thank you!
I tried to download more
I had nearly the same problem. My black tinytunes locked up from static electricity. Even after resetting, it would would freeze up whenever I tried accesing any menu item.
The fix can be found on the Brookstone installation CD. It's a blue, 3-inch disc with "Brookstone" on it. Put it in your computer's CD ROM and it should autoinstall the SigmaTel Audio Player. You may get prompted during installation that some files on your computer are newer than those on the disc. Choose to keep the newer files if this happens.
After the install, connect your TinyTunes to the computer. If you can, copy any files from the player on to your PC as they will be erased in the next step.
Now look for the SigmaTel MSCN Audio Player folder in your program files. Click on "Firmware Download" within. A window will pop up showing the firmware versions. Tick the "Format Data Area" box, then select "Yes" when prompted. Now hit "Start" at the bottom of the box.
At this point, a couple of blue progress bars will run for about fifteen seconds as the firmware loads. When it's finished, hit "close".
Your TinyTunes is as good as new !
Peace.
Marco
Im having plently of trouble with Tiny Tunes.
I had a similar problem. My black tinytunes locked up from static electricity. Even after resetting, it would would freeze up whenever I tried accesing any menu item.
You're done !
Peace.
Marco
How do I turn it off?
Just push and hold the "stop" button. It's the square symbol to the right of "M" (Menu) button.
A three segment "Power Off" progress bar will appear on the screen. When it reaches the end, you can let go of the button.
Peace.
Marco
Frozen Brookstone tiny tunes Mp3 player
You're TinyTunes is as good as new !
Peace.
Marco
My brookstone outdoor wireless speaker does not work on just battery power....never has
There are a few potential reasons why your Brookstone outdoor wireless speaker may not be working on battery power. Here are a few things you can try:
- Make sure the battery is fully charged. If the battery is not fully charged, it may not be able to power the speaker.
- Check the battery connections. Make sure the battery is properly seated in the speaker and that the connections are clean and secure.
- Try a different battery. It's possible that the battery you are using is faulty or has simply reached the end of its lifespan.
- Check for any visible damage to the speaker or battery. If you see any signs of physical damage, this could be the cause of the issue.
- Contact Brookstone for further assistance. If you have tried all of the above steps and the speaker is still not working on battery power, you may need to contact the manufacturer for further assistance.
I hope this helps! Let me know if you have any other questions.
How to fix a CD Play that stops in the middle of a track
Probably dirty laser optics, especially the tracking optic. Go to Walmart or Amazon and get a CD cleaner disc. It has small brushes that clean off dust.https://www.staples.ca/products/786397-en-staples-cd-dvd-drive-cleaner..
Hi. I cannot figure out where the ac power goes into my Brookstone Wafer-thin cd system (2005) there is no where on the system to insert the power cord.
From set up manual Setting up the system takes no time at all. Connect the subwoofer to the main unit with the provided cable. The NXT speakers connect directly to the subwoofer with color-coded cables for left and right. An FM antenna is included and can be connected easily to the rear of the unit (the AM antenna is built in.) Finally, the subwoofer gets plugged into the wall for AC power and the unit can be powered up. If this takes you more than 5 minutes, call your Dad and ask for help, you're probably over-thinking it. There is no setup in terms of volume or bass management configuration as the sub handles all crossover functions as well as volume balancing between itself and the NXT speakers. You can get a copy from manufacturer or online search
