20 Most Recent Niko OTP-2613W 26 in. LCD Television Questions & Answers
It can be unstable DC from power supply due to bad capacitors, or bad main board, it will required in-depth troubleshooting.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Niko OTP-2613W... | Answered on Mar 06, 2011
http://www.bestcompu.com/Products/4624.html
You can purchase the power adapter at that link.
Thank you,
Lee
Niko OTP-2613W... | Answered on Nov 23, 2010
Buy a new tv.The tv u have now,the LCD screen panel it internal screen membrain is broken.The tv,u have now,dosen't worth a whole tv anymore.Tv only now,worth as only as a salvages tv for it electronic boards for parts,that it.The LCD screens panels are 90% important to the LCD tvs,when,that damages or broken.The tvs doesn't worth it to replaced it LCD or Plasma screens,because tvs screens panels are limited produced by the tvs industries,u will not able to buy it anywhere,but the tvs industries themselves.They'll sell it to u,but the same priced as a new tv.
Niko OTP-2613W... | Answered on Oct 28, 2010
Hi and welcome to fixya
To answer your question;
If you`re asking if the tv can receive digital signal, then the answer is no.
This set has only analog NTSC capabilty and not ATSC digital
It is HD ready (not full HD,1080p)which means that is has a max resolution of 1080i
And it doesn`t have HDMI input but DVI-D which is digital but doesn`t carry the sound.
Hope this help
Cheers
Niko OTP-2613W... | Answered on Aug 26, 2010
They are usually Metric M5 or M6, more likely to be M5 for 26" TV. You should be able to get them at hardware store for about 25cents each so you can try different sizes.
http://s807.photobucket.com/home/budm/allalbums
Niko OTP-2613W... | Answered on Jun 25, 2010
changd the settings of your LCD
Niko OTP-2613W... | Answered on Dec 19, 2009
this t5v is a piece of ****
Niko OTP-2613W... | Answered on Dec 05, 2009
man i looked and couldnt find a size but here is a number to a company who might can tell u, its called peerless mounts 1-800-473-3753 good luck
Niko OTP-2613W... | Answered on May 26, 2009
I have pretty much the same problem. When I turnm on the set (Niko OPT-2613W) it is hit or miss whether it will work or no. Some times I get audio with no picture, sometimes the other way around. Sometimes I get sound and picture but no controls work (either the ones directly on the TV or the remote). When I turn the TV ON/OFF multiple times (switch next to the power cord) it generally reverts to working correctly until I turn it off when I'm done watching and then the process starts all over.
I consulted a TV repair shop and was advised that since it was an "off" brand they werent sure they could find the repair manual or parts. I don't want to toss it but it really isn't good the way it is. I haven't tried it as a computer monitor yet but I think it would be fine with VGA input. Unfortunately that's not what I bought it for.
Niko OTP-2613W... | Answered on May 12, 2009
Mostly likely, it is your power supply. Is it getting hot? Most of them have a thermal protection circuit which will shut them off when they get too hot. You can order a new one off Ebay for about $20 -$40 depending on what voltage and current you need.
http://stores.ebay.com/LCDPAYLESS
Make sure you order the correct plug size too for your TV.
Niko OTP-2613W... | Answered on Apr 22, 2009
95% of all LCD's use the standard PC or Monitor cord. Best Buy ect...
Niko OTP-2613W... | Answered on Feb 06, 2009
If you have a set of av cables you can connect one set of the wire to the output of the DVD player while the other line can connect to an input line in the back of your tv.
The av cables have three ends. One cable is yellow, one is red, and the remaining end is either black or white. The jacks in the back of your DVD and TV are color coded to match the wires.
Niko OTP-2613W... | Answered on Jul 27, 2008
Niko OTP-2613W 26 in. LCD Television Logo
30 questions posted
Top Niko Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Andrew Taylor
Andrew Taylor
Are you a Niko Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Niko Televison & Video
Most Popular Question
power indicator but no bright screen or
  • Televison & Video
