20 Most Recent Hyundai Electronics ImageQuest N71S 17" LCD Monitor Questions & Answers
If it does the same when attached to another PC, then please read below.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Hyundai... | Answered on May 15, 2011
When you have white glow and no pictures, then more likely the the LCD T-CON board (part of LCD panel assembly) is not getting 5vdc feeding it, it can be blown fuse on the T-CON board or the logic board is not feeding the 5vdc to the T-CON board.
You need to check the power supply and the logic board first for bad caps (leaking/bulging top).
Please see my pictures here:
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Hyundai... | Answered on May 17, 2010
peter_chadwi, You forgot to mention date of manufacture from the rear cover of monitor??? If unit is out of warranty period you or qualified technician will need to investigate the units switch-mode-power-supply for proper dc voltage output. +5 v or 3.3 v and +12v Whenever strange or weird things start to occur with a cold-cathode-fluorescent-lamp back-lit lcd monitor, I would suspect the culprit to be the SMPS/inverter circuit. Hyundai lcd units have 3 year warranty. Verify that monitor does same at different "known-good" pc!! If unit still has inaccessible "menu" then start warranty service processing. Don't let Hyundai off the hook!
12fixlouie north of Windy City
Hyundai... | Answered on Apr 08, 2010
Send me good clear picture of the Power supply/Inverter baord and the logic board (the board with ribbon cable attached to the LCD panel and the logic board), my email is [email protected]
Hyundai... | Answered on Mar 30, 2010
First of all, the screen glows white means that the inverter circuits are working and the power supply for the inverter is OK (12~18VDC is used for the inverter circuits), 5vdc for logic is more likely to be OK since you can turn it on or off. There isno way any peson can tell for sure hat it is not blown fuse or bad transistor unless he can actually make some voltage testing first. Do you have test equipment and basic knowledge of electronics? Picture will help. You can also see what usually goes bad in the monitors, http://s807.photobucket.com/home/budm/allalbums
not transistor, but it's capacitor problem. It's happen almost to all kind of LCD monitor and TV, just click here to solve your problem.
dm
The screen has white glow and no images means that the LCD controller board (part of the LCD panel) is not getting the 5vdc power feeding it from the logic board through the ribbon cable, it is either the cable came lose or dirty contacts, or failed 5V switching transistor for the LCD controller is bad, or blown fuse on the LCD controller board. See pictures here: http://s807.photobucket.com/home/budm/allalbums
Look at the LCD panel album.
This monitor is sensing information from your computer regarding the configuration. The computer is trying to do the same thing. First, boot the computer in safe mode. This will set the output of the computer to VGA specs. The monitor should work with this spec. If not, then check your connections and try to reset the monitor to factory specs.
This monitor has only a limited number of resolutions and refresh frequencies that it supports. Be sure that your computer is configured to one of these standards.
Beyond that, try on another system, if possible. If it works there, it could be your video card is not compatible with the monitor/monitor not compatible with video card. I had someone give me one of these and it works perfectly. I tried other resolutions and the problem with it shutting down shows up.
Solution: run 1024 x 768 at first, then try to switch to 1280 x 1024.
Hyundai... | Answered on Apr 14, 2009
purchasin757, What type monitor? If lcd type, may have 1 cold solder joint of some component lead on the "switch-mode-power-supply / inverter ballast circuit board, that goes "open" (intermittant) after it reaches a certain unspecified temperature/time period. Unit will need to be investigated by you or electronics technician to find common problem related to all brands of CCFL back-lit LCD monitors. How old did yu say your unit is??? May be that it also need some new electrolytic filter capacitors to be installed on the SMPS/ inverter board to make it servicable for 2 to 4 more years. Lots of video clips you should investigate at YOUTUBE before you return to fixya to do a customer reply and rating of this response to your post. You will also want to do a lot of readng in the fixya profiles of "budmrtn" "12fixlouie" for more info on this (your "black screen of death" symptom) common problem that affects not hundreds, but many thousands of lcd monitors. Let us know what you will do, after you research problem. 12fixlouie
Hyundai... | Answered on Nov 02, 2010
Depends on the problem with it.
Straightforward enough to repair whatever the issue.
Computers &... | Answered 3 hours ago
Good to hear that you want to design an E store.Then leave all your concerns apart be cool and go with http://www.makeanysite.com an amazing platform where the users can build their website and at the same time enjoy more offers like Unlimited Hosting,Free Life time Domain,Unlimited Emails.Unlimited Pages and lots.Highly complex websites with Ecommerce,Blogs, Slide-shows,Forums are the unique features of makeanysite.com
Computers &... | Answered 5 hours ago
you can check the link to find https://bit.ly/31rSHrh
Computers &... | Answered 12 hours ago
Change the default keyboard
From the Home screen, swipe up on an empty spot to have open up the Apps tray and then Tap Settings and General management and Language and input and Default keyboard.Then select the Samsung Keyboard.
Computers &... | Answered 20 hours ago
If it's Model: 100012590, then it appears there's no adjustment.
Computers &... | Answered 23 hours ago
Look at its function, then how to remove it if you still want to:
https://www.google.com/search?client=firefox-b-1-d&q=trayapp
Computers &... | Answered Yesterday
Hyundai Electronics ImageQuest N71S 17" LCD Monitor Logo
Popular Tags
10 questions posted
Top Hyundai Electronics Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Hyundai Electronics Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ImageQuest Hyundai Electronics
  • ImageQuest Hyundai Electronics
Most Popular Question
hyundai n71s monitor
  • Computers & Internet
