20 Most Recent Lexmark X642e All-In-One Laser Printer Questions & Answers
Error message. 924.01 service BEWARE SPAM NUMBER 1-800-532-4187
The 924.01 service fuser error indicates either the fuser unit is not able to reach/maintain the correct temperature or the fuser unit is not working. What you can do:
  • Turn off printer. Turn on after 30 seconds.
  • Plug printer straight to power outlet in the wall. Bypass any surge devices or power strips, they draw away power from the printer.
If problem continues, contact Lexmark technical support(under warranty) or your local authorized service provider for professional repair.
2/11/2021 11:51:19 AM • Lexmark X642e... • Answered on Feb 11, 2021
0answers
0answers
6answers
I forget password and want
Passwords add a level of security to your computer. When sharing a computer with others, your customized settings, computer programs, and system resources are more secure when you assign a password to your logon name or user account name. The steps to perform this task differ depending on whether your computer is a member of a network domain or is part of a workgroup (or is a stand-alone computer). My computer is on a domain You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure. Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password. My computer is not on a domain If no password has been assigned to the user's account, a password will need to be created before it can be changed. For information about creating a password, click Related Topics. The steps to perform this task differ depending on the type of user account you have. If you have a computer administrator account Open User Accounts in Control Panel. Click your account name. Click Change my password. In Type your current password, type your current password. In Type a new password and Type the new password again to confirm, type your new password. You can also enter descriptive or meaningful text in Type a word or phrase to use as a password hint to help you remember your password. Click Change Password. If you have a limited account Open User Accounts in Control Panel. Click Change my password. In Type your current password, type your current password. In Type a new password and Type the new password again to confirm, type the new password. You can also enter descriptive or meaningful text in Type a word or phrase to use as a password hint to help you remember your password. Click Change Password. Notes A user with a computer administrator account can create and change passwords for all users on the computer. Users with limited accounts can create and change their own passwords, as well as create their own password hints. If a user with a computer administrator account changes the password for another user, that user will lose all EFS-encrypted files, personal certificates, and stored passwords for Web sites or network resources. Notes To open User Accounts, click Start, click Control Panel, and then click User Accounts. For more information about user accounts, click Related Topics. Related Topics
6/25/2012 2:18:33 AM • Lexmark X642e... • Answered on Jun 25, 2012
Lexmark x642e error message 954.95
Seems you have a bad interface card.Try replacing it.
11/14/2011 1:25:03 PM • Lexmark X642e... • Answered on Nov 14, 2011
Dando erro de SERVICE FUSOR
S'il vous plaît essayez d'éteindre l'imprimante pendant au moins 30 secondes.
Assurez-vous que l'imprimante est connectée à la prise d'alimentation correcte. Vérifier l'étiquette énergie sur le dos de l'imprimante pour voir si elle fonctionne sur une source 110 ou 220 volts. Vérifiez que la prise d'alimentation correspond à sa tension nominale de travail
Pour plus d'assistance s'il vous plaît contactez le support technique de Lexmark.
7/25/2011 5:33:22 PM • Lexmark X642e... • Answered on Jul 25, 2011
How to delete unwanted Shortcut
If the printer is connected to a network, type the IP address of your printer on the address bar of your web browser. On the printers web interface, click on Configuration and select Security. Click on Function access and select a specific function of the printer, click the drop down button and select function disabled and the click submit.
You may also use the printer operator panel. Click on Menu button >Settings > General Settings> Home Screen customization > select the specific function and select do not display and click on submit.
For further assistance, please contact Lexmark Technical Support.
7/11/2011 1:21:05 PM • Lexmark X642e... • Answered on Jul 11, 2011
Hello, I got an Lexmark
A 900.80 error indicates a problem with the current print job or with a part within the scanner unit of the printer. Please click on the link below to see instructions on how to go about the procedure.
http://bit.ly/qxvmNN
For further assistance, please call Lexmark Technical Support.
7/7/2011 10:45:04 AM • Lexmark X642e... • Answered on Jul 07, 2011
Lexmar X644E enciende carga software
7/7/2011 10:34:24 AM • Lexmark X642e... • Answered on Jul 07, 2011
2answers
My company lexmark X642e all
Make sure you plugged it back into the right port on the printer itself. The one I have actually has two different phone line plug-in ports - one is for the FAX line that connects to the wall. The other is so you can attach a separte phone as an extention to talk on. Good luck. Also, after it is plugged back into the wall, did you power down, wait 30 seconds and then power back on? Sometimes these things need to recognize at start up whether or not they are connected to other devices, etc. Good luck.
7/7/2011 10:26:39 AM • Lexmark X642e... • Answered on Jul 07, 2011
I WORKING ON A LEXMARK
It possible that this is a bad modem, try turning off printer and unplug fax. If you are getting same error message, you need to get a replacement of the modem card.
For further assistance please contact Lexmark Technical Support.
6/29/2011 3:52:00 PM • Lexmark X642e... • Answered on Jun 29, 2011
I installed a maintenance kit (fuser, charge
Have you tried a different cartridge? Was there much spilled toner inside the printer? If you go into menus, and then help menu you can print a print defect guide that you can line up on your print and it will tell you exactly which part is causing the issue.
3/12/2011 7:26:59 AM • Lexmark X642e... • Answered on Mar 12, 2011
Copies made from top feeder produce a line across
the top feeder scanner is not clean and clear service is needed
1/4/2011 2:30:30 PM • Lexmark X642e... • Answered on Jan 04, 2011
I got a new toner cartridge for our x642e and it
Are you referring to the fuser wipers? Maybe this photo will give you an idea:
7/30/2010 9:25:01 PM • Lexmark X642e... • Answered on Jul 30, 2010
Lexmark X642e All-In-One Laser Printer Logo
Popular Tags
46 questions posted
Top Lexmark Office Equipment & Supplies Experts
Marvin
Marvin
Mehandi Husain ...
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
lexmark x642e error message 954 95
  • Office Equipment & Supplies
