20 Most Recent Lexmark Z645 InkJet Photo Printer Questions & Answers
2answers
Printer Spooler service!
hi,buddy
you have to start printer spooler by this.
click "start btn"
click on "run"
write here "services.msc"
double click on "print spooler"
select status type "automatic"
than click on "start"
now install your printer.
2/24/2013 3:45:01 PM • Lexmark Z645... • Answered on Feb 24, 2013
0answers
Lexmark Z645 Printer. NO power. Ordered new power pack source, still no power
Try to plug it in to a different power outlet without any surge protector. If it still doesn't help, then the printer may already be defective.
12/10/2012 8:01:57 PM • Lexmark Z645... • Answered on Dec 10, 2012
Intcartrigde runs from left to right
It could be the encoder strip which is responsible for the proper movement of the cartridge carrier in the carrier assembly inside the printer. Try to check to this article on the Lexmark website to give you an idea on how to re-seat the "plastic ribbon".Printer Cartridge Stalls or Is Blocked
12/30/2011 9:23:38 PM • Lexmark Z645... • Answered on Dec 30, 2011
My printer is showing as
Please follow the steps below to fix the problem:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
9/1/2011 9:43:24 PM • Lexmark Z645... • Answered on Sep 01, 2011
I had to replace my
Have you put the drivers for the printer?
Note some new operating systems like vista may not be able to support your
drivers if the driver was for an older operating system.
If that the case the choice is to revert to an older
operating system or buy a newer model printer.
8/4/2011 12:27:30 PM • Lexmark Z645... • Answered on Aug 04, 2011
I lost my disk for
What is the operating system installed on your computer? If you are using Vista or Windows 7, make sure to check if it's running on 32-bit or 64-bit system type before downloading the driver. On your computer, go to Start menu > right-click on Computer > Properties. Take note of the System Type.
Visit the Lexmark website to download the correct printer driver for your operating system.
8/2/2011 9:06:51 PM • Lexmark Z645... • Answered on Aug 02, 2011
Hi, I own a Lexmark z645
Note: The Lexmark Z645 printer only works on Windows operating system. Unfortunately there are no Lexmark Z645 printer drivers available for Macintosh operating system.
8/1/2011 6:11:48 PM • Lexmark Z645... • Answered on Aug 01, 2011
How to connect the printer
Access the manufacturer's web-site: http://support.lexmark.com
Click "Select Your Product"
Enter 'z645' and do the search.
You'll find that it is a USB device, and that you can download device-drivers from this site.
Download.
Install.
When prompted, connect a USB cable from the printer to the computer.
Finish the install.
7/20/2011 1:01:05 AM • Lexmark Z645... • Answered on Jul 20, 2011
Thyer printer that has printed letters 'till
The firewall is a protection the computer has..and usually blocks some devices or programs to connect to the internet or function ...It is used to mainly protect the computer against the external intruders ...To check if the printer is firewalled ..you have to go into control panel from the start menu..and in there double click the firewall icon ..and on the exceptions ..check the list and see if the printer is ticked...if it is not..tick the case and click ok ...
But ..my advice is to reinstall the printer's driver from scratch ..and after that see if it works...usually when the printer seam to lit up ..and work ..but do not answer to the commands from the computer ..the driver is corrupted and causes the issue ..
To reinstall it clean ..you have to go back in the control panel ...open the add remove programs..and remove the old program for the printer..(you will find it on the list by the printer's name ...there can be more than one program associated with the printer if it is a multifunctional ..)
after that ,,,insert the disk that came with the printer..and run all programs on i t...and follo w the instructions on screen ...At one moment you will be asked to connect the printer..and continue the installation until finish ...or ..you install all programs and after that connect the printer and restart the computer ...Im almost sure that this will fix the issue if the printer do not have a physical damage ..
Have a nice day , and ask for guidance if something causes you misunderstandings ...
7/7/2011 2:28:41 AM • Lexmark Z645... • Answered on Jul 07, 2011
Can only get black when
Hi
Maybe it needs to set up from the printer properties. Right click on the printer and choose PRINTING PREFERENCES OR PRINTING PROPERTIES, then go to color tab and uncheck the PRINT IN GREYSCALE. or choose AUTOMATIC.
If not, it might be the colored ink catridge is clog and need to nozzle cleaning. Try to rub the cartridge nozzle into a plain paper with rubbing alcohol until ink flows and make sure colored ink flows and the try to print again.
If not, it might be the ink cartridge is faulty, try to replace new colored cartridge. Even if it still new purchase but if stuck up for a very long time. Ink might dries up or clogged which makes the ink cartridge defective.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
6/7/2011 4:17:11 PM • Lexmark Z645... • Answered on Jun 07, 2011
I have installed a new
Doing the "clean printhead/cartridge nozzles" multiple times would have cleared clogged nozzles. You can also try to manually wipe the cartridge nozzles with a slightly moistened soft cloth. If that still won't help, try to replace your cartridge with a different known working cartridge to determine if your other cartridge is faulty.
5/12/2011 3:34:58 PM • Lexmark Z645... • Answered on May 12, 2011
It says that the printer
Ensure that the cables are properly connected; you need to ensure that your printer is properly connected, and plugged in, and also the cable is accurately connected to the computer as well.
Check the power; make sure that the printer's power is switched on, ensure that all the computer necessary computer components are also turned on.
Make sure that the hardware is properly plugged in, and also turned on. Apply troubleshooting.
A troubleshooter is a tool, which is generated automatically and which can easily fix the problems that occur with your system.
Thus, if you are coming across different issues related to your printer, then you can consult the troubleshooter.
You require driver applications to run your hardware devices.
Make sure that the drivers are not outdated, corrupt, or incompatible, resulting in disrupting the communication between the printer and the computer.
Always make sure that you are making use of the most recent and latest device drivers, and also that are compatible with your system requirements and specifications, as this can be extremely useful in resolving printer issues.
5/4/2011 3:49:54 AM • Lexmark Z645... • Answered on May 04, 2011
Lexmark Z645 InkJet Photo Printer Logo
136 questions posted
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Marvin
Marvin
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Z Lexmark
  • Z Lexmark
Most Popular Question
lexmark z645 printer no power ordered
  • Office Equipment & Supplies
