20 Most Recent
Soundstream XTA880.2 Car Audio Amplifier Questions & Answers
Amp is on even when
make sure the power wire isnt touching even a little bit....had the same problem with an explod amp and one little strand of the positive wire was just touching the remote wire terminal and keeping it on.
Power light on but no
I would check the subs for resistance. If the Voice Coil of the subs shows an Open Circuit, your subs are blown. It is possible that the wiring inside the box has come loose, or the wiring from the amplifier to your sub box is loose or disconnected. I would then check the RCA or signal wires from the Head Unit to the Amplifier. The fuse is fine, and wouldn't make a difference in your situation. I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Why does it say can't watch video while driving how do I ignore that on my Soundstream VR-769NB
It is a safety feature so you won't won't drive while watching a video or movie while driving.It makes you wonder why they would even make an up front dvd player with a screen if it is illegal ! (And it is !) So now your parents won't be mad at me because I can't give you the solution to make it where you can see it ! I probably just saved your life and someone else's ! Don't be mad or give me a bad review here I just care about human life enough to not help you get into an accident! Good Luck !
