20 Most Recent HP LaserJet M3027x MFP Printer Questions & Answers
0answers
2answers
The roller in the feeder has come out, I don't
I am not sure as to which roller you are talking about but please find below the solution. !!!!DO RATE MY SOLUTION!!!Pickup roller replacement
  1. Tip the device over on its rear side, with the top of the device facing you.
  2. Rotate the bushings (callout 1) on each side of the roller upward. c02755446.gif
  3. Remove the left-side bushing by sliding the bushing to the left.
  4. Slide the roller and shaft toward the left until they clear the hole in the right-side bushing, and then lift the right end of the shaft.
  5. Slide the roller and shaft toward the right, and then lift the roller and shaft together out of the device. c02755447.gif -------------------------------------------------------------------------------------------------------------- This is for ADF (Automatic Document Feeder) on top of the printer.
    3. Press the round blue button while lifting the green lever. Rotate the green lever until it stops in the open position. The pickup roller assembly should remain on the surface.c00802892.gif
    4. Remove the assembly, and then wipe the assembly with a soft, dry, lint-free cloth.c00802893.gif
    5. Replace the assembly, with the largest roller down, in the upright holder, and then press until the assembly snaps into place.c00802894.gif
    6. Make sure that both sides of the assembly are secured by the blue hooks.c00802895.gif
    7. Lower the roller assembly, and then close the ADF cover.c00802896.gif NOTE: If jams continue in the ADF, contact a local HP-authorized service provider.
8/9/2016 8:04:45 PM • HP LaserJet... • Answered on Aug 09, 2016
Error code FF09
User's manual should be a PDF included in your software install CD. You will probably want to access that next time.
4/27/2015 2:44:44 PM • HP LaserJet... • Answered on Apr 27, 2015
Can't get a clean print job
clean the printer back side of the sensor & check.
12/19/2013 10:28:37 AM • HP LaserJet... • Answered on Dec 19, 2013
Blank pages
Are you checked cartridge contacts left side of the cartridge bank, you can observe three flexible plastic shells representing the contacts to cartridge,, check them there is the problem....
2/2/2012 2:17:59 PM • HP LaserJet... • Answered on Feb 02, 2012
HP M3027X - has 52.00 error code. We replaced the
1. Verify that the laser/scanner motorconnector and the ribbon cable fromthe ECU are firmly seated on the laser/scanner assembly.2. Verify that the laser/scanner motorconnector is firmly seated in connectorJ402 on the ECU. You might have toremove the main cooling fan to seethis connection.3. Verify that the ribbon cable installed inconnector J403 on the ECU is fullyseated. You must remove the ECU inorder to verify this connection.4. If, after checking the cables, themessage persists, replace the laser/scanner5. If, after replacing the laser/scanner,the message persists, replace theECU Replacing the ECU isn't pretty. If you haven't done it before, you probably should get someone that has.
9/30/2011 5:18:02 AM • HP LaserJet... • Answered on Sep 30, 2011
Mfp 3027 is making a
If it is making a wah wah sound when printing, or grinding, the problem is the bushings on the lower pressure roller. Remove the fuser again and check the bushing on the driven side of the fuser. If there is a bunch of dust and you can see a visible gap between the shaft of the pressure roller and the bushing then that is the cause of your problem. If the printer has less than 150,000 pages on it, stop now and do not disassemble anymore of the fuser, see my tip here, as the fuser is covered under an extended warranty by HP. Act quickly though as this warranty extension expires on June 30th.
6/16/2011 7:55:31 PM • HP LaserJet... • Answered on Jun 16, 2011
Modem error 82
You can get an 82 error if you are trying to send a fax at the same time one is being received.
If that isn't the case for you, and power cycling the printer didn't help, you are going to have to log a service call.
The fax module may have to be replaced.
Sorry.
12/15/2010 8:30:16 PM • HP LaserJet... • Answered on Dec 15, 2010
I need this machine to send me a confirmation
hi
go to following link you will find all answers
http://thedailyreviewer.com/server/view/fax-send-confirmation-10488758
10/8/2010 4:20:47 PM • HP LaserJet... • Answered on Oct 08, 2010
2answers
Can I scan from a
SMTP server means a mail server. You do not need that to share your scanner/printer with you MAC. All you have to do is to enable sharing the printer with a network and then connect to that network on your MAC, obviously through wi-fi.
6/27/2010 4:57:25 AM • HP LaserJet... • Answered on Jun 27, 2010
FAX CONFIRMATION PAGE
Touch ADMINISTRATION then touch CONFIGURATION PAGES then MENUMAP and that will print a guide for you to look for FAX REPORTS and when to print them. You can also have a thumbnail put on a report
5/14/2010 7:40:46 PM • HP LaserJet... • Answered on May 14, 2010
Roller on tray 2 keeps wearing out
use last paper
1/13/2010 3:43:44 PM • HP LaserJet... • Answered on Jan 13, 2010
HP LaserJet Pro MFP M130fw. Error code 58.04 Laser jet pro mfp m130fw
Question edited for clarity and toss in a load of CAPS. Question moved from 'Jet Office Equipment' category. It's not good!
HP Color LaserJet Pro MFP M477
Printcopy.info https://printcopy.info > brand=HP > code=58 Code: 58.04; Display: 58.XX Error, Turn off then on; Description: The product has experienced an error with the low voltage power supply. Missing: M130fw. ‎' Show results with: M130fw.
58.04 printer display error on powerup
HP Support Community https://h30434.www3.hp.com > td-p Aug 2, 2018 - THE ERROR CODE PROBLEM OF MOTOR POWERSUPPLY BOARD (SMALL DAUGHTER BOARD TOP OF THE SCANNER UNIT), Transistor no of 905,903 like ..before you change check motor ... My printer is displaying, "58.04 Error power outage detected... Jun 28, 2022 Laserjet Pro 400 MFP 451dn error message 58.04 Aug 5, 2013 My laser jet MFP M477fdw printer is showing 58.04 error cont... Sep 22, 2021 HP M451 Error 58.04 - HP Support Community - 5830295 Nov 1, 2016 More results from h30434.www3.hp.com Missing: M130fw. ‎' Show results with: M130fw.
Error Codes > HP > LaserJet Pro MFP M130 > Code 58.XX
Printcopy.info https://printcopy.info > brand=HP > code=58 Code: 58.XX; Description: The product has experienced an error with the low voltage power supply. • 58.04 = Low voltage power supply malfunction; Remedy: 1. ..
1/13/2024 5:59:42 AM • HP LaserJet... • Answered on Jan 13, 2024
13.B2.D3 laserjet 4555 mfp keeps happening
4/24/2023 5:38:52 PM • HP LaserJet... • Answered on Apr 24, 2023
HP LaserJet M3027x MFP Printer Logo
21 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
roller in feeder come out don 39 t
  • Office Equipment & Supplies
