20 Most Recent Amana DRS2663B Side by Side Refrigerator Questions & Answers
You will need to replace the defrost thermostat located on the coils. Here is the part to order.
Amana DRS2663B... | Answered on Dec 03, 2012
I believe your Amana DRS2663B Click Here=> 67006000 SOLENOID
has failed and may need to be checked out this is the part that opens the door for the ice dispenser. Click Here=> Amana DRS2663B Dispenser Facade Removal Instructions
As a Whirlpol Technician this is the only way to get to these parts to find exactly what is happening. Should you have other Tech questions I will be here or on our new Beta Fixya Website, Please rate if helpful, Thank You Sea Breeze
Amana DRS2663B... | Answered on Oct 14, 2011
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Amana DRS2663B... | Answered on Apr 08, 2011
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Amana DRS2663B... | Answered on Jan 30, 2011
This uses a dual water valve each with its on solenoid coil. Remove the black cover in back, locate valve and switch wires on the coils. If you now get water to the ice maker change the valve.
Amana DRS2663B... | Answered on Nov 18, 2010
You should never need to advance your defrost timer. If your defrost is not working properly, the coil in the freezer compartment will ice up, blocking all airflow. All of your cooling is done there, even the refrig area, so you will never get down below appx. 40-45 degrees.
my first suggestion is to look at the back panel in your freezer for frost/ice build-up. If yes, unplug the unit, open the freezer compartment and let it thaw overnight. If it starts cooling properly, you have a defrost problem. It may be a bad timer(often), thermostat(less frequent), or bad defrost heater(even less).
Amana DRS2663B... | Answered on Nov 15, 2010
The evap coil is most likely frozen over inside the freezer. If it is, it is either the defrost thermostat, defrost control or defrost heater at fault.
Amana DRS2663B... | Answered on Nov 11, 2010
You may have a bad relay/overload part number 12555902 runs about $15 but if the compressor is going bad it may not work.If you take the relay/overload off  turn it into your hand and shake it if you it sprinkles out like a pepper shaker go with the OEM part afore mentioned,but if it sounds solid and nothing comes out go with a hard start(SUPCO RC0410 also about $15) it will buy you at least another couple years in which to shop around for a replacement or save the money for a new compressor.You can call Amana to check on the warranty but most only had five years on sealed system.
Amana DRS2663B... | Answered on Sep 27, 2009
usually in back on top of or near compressor or in the front of fridge u have to remove the panel to see it
Amana... | Answered on Mar 12, 2020
pan is usually located on back or front bottom you may have to remove back or front pANEL TO ACCESS
gently possible soft brush or coil comb
Amana... | Answered on Mar 11, 2020
Hello Dennis;
My name is Peter. I am a retired field service technician.
You did not provide a model number. So, I am going to speak in general. It sounds like you have a bad or stuck contact switch. Or, you ice dispenser handle is broken and activating the dispenser.
You contact switch will look like the following:
There are two slots on the bottom of the dispenser frame for a flat head screw driver. Pop the bottom out. The rest of the frame is held by plastic tabs. Push in the sides to remove the frame.
Ground yourself by touching something that is steal. Static electricity will knock out a board. Remove the board. You will see the contact switch.
Send me the model number and I can be more specific.
Go into the following web site and put in your model number for diagrams and the part number.
Water Filters Lawn Garden Appliance Parts
Amana... | Answered on Jan 08, 2020
Check the plastic drainage tray atop the coils at the bottom underneath. You probably will find a smelly stew waiting to be drained into the sink. Follow up by scrubbing the tray clean.
Amana... | Answered on Dec 02, 2019
That can be two things.
1. Condensation
2. The evaporator is in there behind the grill with a small fan. It freezes up and has a defrost which causes water. That water runs into a drain, your drain is blocked or the fan isn't working.
28 years old, you are due for a new one.
Amana... | Answered on Oct 21, 2019
This appears to be a reference to the defrosting component of a Amana freezer. Let's just assume that it is not a problem with the freezer door seals. (If the seal is not a tight seal when the door is closed, you have melting occurring and the the freezer trying to compensate by refreezing, yielding a lot of icing in the compartment. This is what happens if you over stuff the freezer and the freezer door does not quite close firmly, as well.)
The Amana defrost thermostat might be defective or have become dislodged for some reason. If defective, it would require replacement. But let's say it is not defective. The defroster didn't work when there was too much ice buildup. This could cause the molex connector in the thermostat to contract, breaking the connect activating it. One user "fixed" this problem by putting aluminum foil inside the molex connector.
If the theromostate became dislodged from its "attachment point", one would need to know the model of the freezer know where that point was. https://www.applianceblog.com/mainforums/threads/amana-defrost-thermostat-installation-location.27405/
There are videos describing replacement of the thermostat in some Amana's. You can find such on YouTube. I just can't promise that replacement would fix the problem.
Amana... | Answered on Oct 04, 2019
Amana DRS2663B Side by Side Refrigerator Logo
Popular Tags
14 questions posted
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
amana sxs model drs2663b about
  • Refrigerators
