20 Most Recent Amana ARB220ZCS Bottom Freezer Refrigerator Questions & Answers
Temperature setting/changes takes more than 2 hours to stabilize.If still running non stop after 24 hours use a digital thermometer to check the internal temp of refrigerator. If not cold enough it will not open the thermometer and turn off the compressor. Meanwhile, a 20 minute defrost cycle is about right.
Amana ARB220ZCS... | Answered on Sep 23, 2017
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Amana ARB220ZCS... | Answered on Aug 10, 2011
I want you to try something but if it does not work please let me slide on the low rates. I have seen this happen a lot when the defrost timer goes into defrost the switch is in a place on timer that causes a weak timer to stop there if timer is defective. Your timer is part number Click Here=> 67001036 You will find it inside the fresh food section and behind the control panel=> ARB220ZCS_Controls In that photo you will see a number 12 and that is the timer location. Most refrigerators will have a hole going through the control panel (with plastic plug to hide hole) so you can place a flathead screwdriver inside and slowly turn clockwise. If compressor and fans come back on just replace timer. You also may have a bad thermostat. If compressor was quickly starting and then stopping I would look for something in the compressor area. But these symptoms seem to stick out for me, Thanks Sea Breeze
Amana ARB220ZCS... | Answered on Jul 18, 2011
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Amana ARB220ZCS... | Answered on Mar 20, 2011
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Amana ARB220ZCS... | Answered on Dec 14, 2010
usually in back on top of or near compressor or in the front of fridge u have to remove the panel to see it
Amana... | Answered on Mar 12, 2020
pan is usually located on back or front bottom you may have to remove back or front pANEL TO ACCESS
gently possible soft brush or coil comb
Amana... | Answered on Mar 11, 2020
Hello Dennis;
My name is Peter. I am a retired field service technician.
You did not provide a model number. So, I am going to speak in general. It sounds like you have a bad or stuck contact switch. Or, you ice dispenser handle is broken and activating the dispenser.
You contact switch will look like the following:
There are two slots on the bottom of the dispenser frame for a flat head screw driver. Pop the bottom out. The rest of the frame is held by plastic tabs. Push in the sides to remove the frame.
Ground yourself by touching something that is steal. Static electricity will knock out a board. Remove the board. You will see the contact switch.
Send me the model number and I can be more specific.
Go into the following web site and put in your model number for diagrams and the part number.
Water Filters Lawn Garden Appliance Parts
Amana... | Answered on Jan 08, 2020
Check the plastic drainage tray atop the coils at the bottom underneath. You probably will find a smelly stew waiting to be drained into the sink. Follow up by scrubbing the tray clean.
Amana... | Answered on Dec 02, 2019
That can be two things.
1. Condensation
2. The evaporator is in there behind the grill with a small fan. It freezes up and has a defrost which causes water. That water runs into a drain, your drain is blocked or the fan isn't working.
28 years old, you are due for a new one.
Amana... | Answered on Oct 21, 2019
This appears to be a reference to the defrosting component of a Amana freezer. Let's just assume that it is not a problem with the freezer door seals. (If the seal is not a tight seal when the door is closed, you have melting occurring and the the freezer trying to compensate by refreezing, yielding a lot of icing in the compartment. This is what happens if you over stuff the freezer and the freezer door does not quite close firmly, as well.)
The Amana defrost thermostat might be defective or have become dislodged for some reason. If defective, it would require replacement. But let's say it is not defective. The defroster didn't work when there was too much ice buildup. This could cause the molex connector in the thermostat to contract, breaking the connect activating it. One user "fixed" this problem by putting aluminum foil inside the molex connector.
If the theromostate became dislodged from its "attachment point", one would need to know the model of the freezer know where that point was. https://www.applianceblog.com/mainforums/threads/amana-defrost-thermostat-installation-location.27405/
There are videos describing replacement of the thermostat in some Amana's. You can find such on YouTube. I just can't promise that replacement would fix the problem.
Amana... | Answered on Oct 04, 2019
Check first that there is no leak coming through your gasket a good way is stick a flashlight inside your freezer turn out the lights if you see and beam or light the seal is cracked or must be replaced the check your coils where Freon is supplied if there not cold you must to a pressure test while adding Freon also check for leaks by spraying water on your coils . It's a matter of mathematical elimination also check thermostat if your Amana is under 10 years old look for the fault codes and get someone that can read what faults are being detected
Amana... | Answered on Sep 13, 2019
Probable failure. A common problem with icemakers.
Amana... | Answered on Sep 06, 2019
Amana ARB220ZCS Bottom Freezer Refrigerator Logo
Popular Tags
12 questions posted
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
compressor running non stop
  • Refrigerators
