20 Most Recent Maxi-Cosi Cabrio Red Flame Reflection Infant Car Seat Questions & Answers
2answers
Need replacement hood/sunshade for maxi-cosi
If you follow this link, you will be able to purchase this part:
http://www.maxi-cosi.com/maxicosi/forms/contact.aspx?mode=contact&language=gb-en
I hope this helps.
10/13/2022 1:57:07 PM • Maxi-Cosi Cabrio... • Answered on Oct 13, 2022
Replacing washed cover of I toddler car seat
Hi Instructions on removal of carseat fabric can be found in your User Manual. If you no longer have the User Manual visit www.maxi-cosi.com and select the country you're in, then choose the carseat you have and click the Service tab to download a replacement copy.
8/17/2014 6:24:55 PM • Maxi-Cosi Cabrio... • Answered on Aug 17, 2014
Indicator lights on easyfix base cabriofix not
HiThis would indicate that the carseat is not correctly installed onto the base or that the base is not correctly installed into the car on the IsoFix points.
5/12/2013 11:07:33 AM • Maxi-Cosi Cabrio... • Answered on May 12, 2013
PIERRE CARDIN BABY CARRIER
HiDue to the safety implications of the carseat harness being incorrectly fitted if the harness has been completely removed from the carseat shell it would need to be sent to engineers for them to re-fit the harness. What country are you in we can direct you to the appropriate customer care team to arrange this.
3/3/2013 11:35:12 AM • Maxi-Cosi Cabrio... • Answered on Mar 03, 2013
The seat tilts after correct installation with buckle
HiThis is not a realistic movement for the carseat - it wouldn't be tilted like this in an accident so it is not something that can correctly confirm a good fitting.Was the carseat fitted by a trained member of staff prior to purchase and confirmed suitable? Did they demonstrate how to correctly fit it using the seatbelt only?
3/3/2013 11:11:43 AM • Maxi-Cosi Cabrio... • Answered on Mar 03, 2013
We have just had our 2nd Child and strated using our current Maxi Cosi Cabrio Fix Seat with Iso Fix base. However, it has stopped clicking into the base! We know it previously worked, but the small
HiThe Maxi Cosi CabrioFix carseat can be used with the EasyFix or the FamilyFix base (both fitted with IsoFix)In the event that the seat will not click into position on the base it will need inspection / repair work.
If you're in the UK and the product is under 2 years old, please contact your retailer with your proof of purchase and they can arrange for it to be sent to our engineers for inspection / repair work required under warranty. If you're in the UK and the product is over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to discuss booking it in for chargeable inspection / repair work required.
If you're outside the UK please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab on the right side for your enquiry to be sent through to the customer care team in your country.
2/17/2013 11:50:14 AM • Maxi-Cosi Cabrio... • Answered on Feb 17, 2013
Hello can you buy spare pads for shoulder straps
look on ebay or any black or red ones will be fine my sister used her pads with my car seat
10/30/2011 6:26:13 PM • Maxi-Cosi Cabrio... • Answered on Oct 30, 2011
Can I get replacement straps
Your Maxi Cosi CabrioFix can be fitted with new straps.Since this is directly affecting the safety of the seat the procedure is only available from a Maxi Cosi service center.Please visit a Maxi Cosi dealer to have your seat sent to a service center.I hope this helps.Erwin de Raadwww.babycare.nl
9/29/2011 6:22:24 PM • Maxi-Cosi Cabrio... • Answered on Sep 29, 2011
2answers
I have given my carseat to a friend,and it is
yes try babys or us
11/10/2010 2:50:32 PM • Maxi-Cosi Cabrio... • Answered on Nov 10, 2010
Maxi cosi car seat for a quinny buggy
Go to the Maxi Cosi website, choose your carseat model and there are Instructions online. It's a bit fiddly but once you've done it once or twice you'll find it easy.
7/8/2010 2:24:34 PM • Maxi-Cosi Cabrio... • Answered on Jul 08, 2010
The polystyrene lining on our car seat has
Hello Mike,
You can call this number and see if they will be able to send you the replacement for this. Here is the number. 1-800-951-4113. There is also a website www.maxi-cosi.com check it out and let me know if this worked for you.
Thank you
5/3/2010 9:05:21 PM • Maxi-Cosi Cabrio... • Answered on May 03, 2010
Have a maxi cosy car seat and can i remove seat
www.buggypitstop.co.uk are a professnal cleaning company and they clean car seats including maxi cosi, they should be able to help you
12/10/2009 7:24:14 PM • Maxi-Cosi Cabrio... • Answered on Dec 10, 2009
Can this be secured with just a lap belt?
Hi,.
Absolutely NOT. This carseat does require a three-point seat belt to be correctly and safely installed.
10/11/2009 6:27:56 PM • Maxi-Cosi Cabrio... • Answered on Oct 11, 2009
Fixing maxicosi seat to base
If you have a Cabrio Fix carseat, underneath the carseat should be two silver metal bars that slot into the base, if these are not on the carseat then you have the Cabrio model which is not compatible with the base.
I hope this helps.
9/15/2009 2:23:36 PM • Maxi-Cosi Cabrio... • Answered on Sep 15, 2009
Hi. i have recently bought a maxi cosi cabrio fit
If you visit www.maxi-cosi.com you will be able to download a user manual.
I hope this helps.
9/15/2009 1:48:14 PM • Maxi-Cosi Cabrio... • Answered on Sep 15, 2009
Maxi Cosi Cabrio
I know they do the Black Reflection cover on Kiddicare.com. If you are looking to sell the pink cover you have I would be interested in buying it. Heres my email address, if you would like to sell it let me know. [email protected] Many thanks.
9/29/2008 6:25:12 AM • Maxi-Cosi Cabrio... • Answered on Sep 29, 2008
Repair broken wire on Maxi-Cosi 2wayfix base.
Hello In some countries Maxi-Cosi do have service centres where inspection & repair is possible. You should contact your local Maxi-Cosi office (Facebook or via Maxi-Cosi website, "Contact Us" option) They will be able to advise you.
11/15/2019 8:47:48 PM • Maxi-Cosi Baby... • Answered on Nov 15, 2019
Maxi-Cosi Cabrio Red Flame Reflection Infant Car Seat Logo
24 questions posted
Top Maxi-Cosi Baby Gear Experts
Marvin
Marvin
ray gallant
ADMIN Andrew
ADMIN Andrew
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
View Most Popular
Maxi-Cosi Baby Gear
  • Maxi-Cosi Baby Gear
Most Popular Question
maxi cosi car seat quinny buggy
  • Baby Gear
