20 Most Recent Samsung YP-U2JQB MP3 Player Questions & Answers
Please check that the lock / hold button is not engaged. You can download the manual from the link below: http://downloadcenter.samsung.com/content/UM/200604/20060401094436140_YPU2J-USA-ENGLISH0.0.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Samsung YP-U2JQB... | Answered on Apr 15, 2014
Hello Dear:
you need to upgrade your firmware version by going the samsung site and search your player model number and download the current firmware instal the setup in your pc and connect your player in the pc usb but remember your player is still powerd off
and upgrade the firmware Thats it
Samsung YP-U2JQB... | Answered on Feb 09, 2010
hi: u can need to firmwre updater by searching the samsung site go to site and search the software version by your player model number and download the current updater...
Thanks
It seems that the songs you are downloading in your MP3 player are not compatible with your MP3 player.
check the compatibility in the manual of your MP3 player.
check the format of songs before downloading.
THANK YOU for contacting fixya.com
Samsung YP-U2JQB... | Answered on Oct 18, 2009
Hold Down The M (Menu button) Scroll down to settings, select play mode. Exit out of he menu, press the user button until the squiggly cross with the A appears. Whalaaa you're in shuffle Mode. I hope this was a detailed solution.
Samsung YP-U2JQB... | Answered on Aug 01, 2009
Refer to the user manual. All the operating details are given there.
Samsung YP-U2JQB... | Answered on Jul 20, 2009
what you do is you right cick on the song you want to delete and it will say delet then cick on that
Samsung YP-U2JQB... | Answered on Jun 13, 2009
With regards to this issue, I would suggest you to download windows update since samsung MTP devices are generic driver loaded by microsoft. Then after you have downloaded the windows update press and hold the play button of your device while you are connecting it to your computer, if this is successful a Found new hardware message will pop up on your screen then just follow the on screen instruction on how to install your device. Hope this helps. PEACE!
Samsung YP-U2JQB... | Answered on Apr 17, 2009
check wether you use media player 10 or 11. If you have 11 remove all traces of it and either rollback or re-install 10. You will have to reboot your laptop once you have put media player 10 on.
Samsung YP-U2JQB... | Answered on Mar 05, 2009
I have one that had the same problem. I solder the jack back on but noticed that the solder pad came off the circuit board. Look at the circuit board and find the component where the connection from the solder pad leads. Using a piece of wire you should be able make a new connection. even after Soldering the jack back on, check to see if the pads inside the jack are bulging out enough to connect to the headphones. The constant wear and tear from rocking the headphone jack back and forth is what causes it to "brake". Could happen when its on your pocket.
Samsung YP-U2JQB... | Answered on Aug 28, 2008
go an suc my balls hahahaha!!!!!!!!!
Samsung YP-U2JQB... | Answered on Aug 15, 2008
Can I post a solution without being registered?
Samsung YP-U2JQB... | Answered on Aug 05, 2008
thats weird because mine went through the wash and its oerfectly fine.
make sure you mom didnt over heat the wires or anything inside of your mp3. its possible that your mom fried it.
Samsung YP-U2JQB... | Answered on May 03, 2008
Connect device.Go to My Computer.Click on the device's icon. Click on the folder that says music.Then just right click music files you want to delete and delete them.
hope it helps!!!!!!
Samsung YP-U2JQB... | Answered on Apr 30, 2008
you must pt it in the folder or it will not work. internal storage is for the system. It removes the dates and stuff because windows media player does it
Samsung YP-U2JQB... | Answered on Apr 26, 2008
by connecting to the coomputer
Samsung YP-U2JQB... | Answered on Apr 13, 2008
Samsung YP-U2JQB MP3 Player Logo
Popular Tags
34 questions posted
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
YP Samsung
  • YP Samsung
Most Popular Question
mp3 player always tells need format w
  • Audio Players & Recorders
