20 Most Recent Pentax Optio E30 Digital Camera Questions & Answers
Hi Keith, The link below is the user manual for the Pentax Optio E30 Digital Camera, On page 56 it says • In Green Mode, you cannot change the information displayed on the LCD monitor by pressing the 4/W button. • You cannot use the [A Rec. Mode] menu or Capture Mode Palette in Green Mode. If you try to display the [A Rec. Mode] menu or Capture Mode Palette, - (key lock icon) appears. • If you switched to Q mode from Green Mode, you cannot display the [H Setting] menu by pressing the 3 button. If you try to display the [H Setting] menu, - (key lock icon) appears. • When the camera is turned off in the Green Mode, it turns on in the Green Mode next time the power switch is pressed. THIS IS YOUR CAMERAS USER MANUAL.....CHEERS.. http://www.camera-usermanual.com/manuals/pentax/Pentax_Optio_E30.pdf
Pentax Optio E30... • Answered on Mar 27, 2016
Follow the instructions on page 104 of the manual.
Pentax Optio E30... • Answered on Aug 31, 2012
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ACDSee or any other photo cataloging program.
Consider NOT connecting your camera to your laptop. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Pentax Optio E30... • Answered on Jul 28, 2012
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTERIf your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Pentax Optio E30... • Answered on Jul 23, 2012
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Pentax Optio E30... • Answered on Sep 06, 2011
Hi, Did it just start doing that? As well are there any other buttons not workings?
Pentax Optio E30... • Answered on Aug 01, 2011
My Optio E30 was not zooming because the small ribbon cable from the button strip was dirty/oxidized. All of the back panel buttons are on the same button strip. I needed to open the camera and remove the ribbon from the connector and gently clean the ribbon cable contacts with 600 grit sand paper. It now zooms perfectly.
Pentax Optio E30... • Answered on Jul 02, 2011
The instructions are in the "Copying images and Sound Files" section of the manual (page 109 in my copy). If you need a manual, you can download one at
http://www.pentaximaging.com/files/manual/E30_E.pdf
Pentax Optio E30... • Answered on Jul 01, 2011
If it's like mine just was, it's probably stuck in green mode. If that's the case, just hold the delete button for a bit and it should go away and allow menus again.
Pentax Optio E30... • Answered on Jun 21, 2011
Pentax Optio E30 Digital Camera Logo
58 questions posted
Top Pentax Cameras Experts
halotheracer
halotheracer
Steven Wander
Steven Wander
Mat Kramer
Mat Kramer
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Optio Pentax
  • Optio Pentax
Most Popular Question
download images from e30 laptop xp
  • Cameras
