20 Most Recent Niko SV3206 32 in. LCD Television Questions & Answers
You need to find out if the problem is with the remote or the tv: locate the remote/IR sensor and cover it with a thick black tape. If you still have the same problem then the defect is internal: the control processor is defective - it's unstable and it reacts randomly to nonexistent commands. This is a hardware defect, not a software/settings one: the processor itself is failing and the mainboard of your tv will have to be replaced. You can't replace just the processor, it's glued in there.
BTW yes, Niko and Nikko are the same - different brands for identical products from the same manufacturer.
Niko SV3206 32... | Answered on Jan 16, 2011
did u check the fuse
Niko SV3206 32... | Answered on Dec 16, 2010
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Niko SV3206 32... | Answered on Oct 23, 2010
Here's their website:
http://www.viewtekcorp.com/
You can contact them at:
Viewtek Corp.
20957 E. Currier RD, Unit# G
Walnut, CA 91789
Tel: 909-598-6608
Fax: 909-598-6008
E-mail: [email protected]
Hope that helps! Please don't forget to rate this as Fixya!
Cheers!
ID
Niko SV3206 32... | Answered on Jul 19, 2010
the logitech Harmony line controls the niko 32" as well
Niko SV3206 32... | Answered on May 26, 2010
check for the power supply is locater at the back of the tv..you need to open the cover.the output power of the the power supply is 5vdc for the cpu and 12v-24dc for the backlights..visually inspect the components of the power supply.replace any burned capacitors and resistors..replace the secondary fuse with the same ratings..
Niko SV3206 32... | Answered on May 17, 2010
Hi if you look on the back there will be four holes measure the distance between two from left to right and reference it to the sizes the wall mounts say they do between . i bought mine on ebay its really nice and the price was great...
Niko SV3206 32... | Answered on Feb 02, 2010
Are you trying to turn on with just the remote? I have to unplug mine and plug back in to get it on.
Niko SV3206 32... | Answered on Jan 10, 2010
Mine is kinda tempermental also. When it won't come on or turn off with the remote ,or gets a double image on the screen,I have to unplug for a couple of minutes and then it starts to work. Don't know why.?
Give it a try
unplug for a couple of minutes then plug back in and try
Niko SV3206 32 in. LCD Television Logo
24 questions posted
Top Niko Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Andrew Taylor
Andrew Taylor
Are you a Niko Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Niko Televison & Video
Most Popular Question
new niko remote without instructions
  • Televison & Video
