20 Most Recent AOC 193FW LCD Monitor Questions & Answers
Monitor flashes the "AOC Eyes Value" logo without evr turning on
Man that really hurts.
Flashing logo of company on monitor screen means your monitor has power but not receiving data. Have to find a way to fix data, may be data cable ( vga cable ) of booting of computer itself
Try few things not sure solve your problem or not but really doesnt hurt to try
First, It looks you have loose VGA cabling. Try removing VGA cable completely and connect again
Link how VGA cable looks like
http://files.sandberg.it/products/images/lg/501-93_lg.jpg
Second, if above doesnt solve the problem, may be your VGA card has problem or your CPU is not booting up. Feel the breeze of fan on SMPS to see if it is working or not.
Hope this helps
5/4/2014 3:35:21 PM • AOC 193FW LCD... • Answered on May 04, 2014
I would like to remove the OSD warning pop out
If you are getting a message that says something like "Check cables" " no signal detected" or something like that, it is likely that your monitor is operating correctly. I would suggest checking your cables, make sure that the computer is turned on, and if that doesn't help, check if your monitor has VGA, DVI, or HDMI inputs. I am thinking that your monitor may be trying to display from the wrong source. This is what a VGA (analog) cable looks like. VGA cables are typically blue.
Another common connection that is used is a digital HDMI (left) or DVI (right) connection. DVI cables often have white end connectors. How your PC connects to your monitor will determine the source mode you want to use on your monitor. (Obviously this is the cable view but the connection on the monitor itself will look similar.)
If none of these tips helps, I would suggest hooking the same monitor up to a different PC or laptop, and trying once again to get a the display working. Again, make sure that the connection matches the source setting on your monitor. If it works on another PC, then your computer may have a video problem.
Otherwise, if it still does not work your monitor have a problem displaying via that connection. If possible I would suggest switching to a different type of cable and re-try the above steps.
3/20/2011 4:22:29 AM • AOC 193FW LCD... • Answered on Mar 20, 2011
Im trying to use my
You need to find out first if it does the same when attach to another PC, you may have problem with the monitor itself.
If it is the monitor:
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
2/27/2011 5:54:32 AM • AOC 193FW LCD... • Answered on Feb 27, 2011
I have aoc lcd monitor,
It sounds like there is no signal to the monitor. The computer you have, does it work if you hook up another monitor? Have you taken this monitor to maybe a friends house or neighbor? See if it works. If it does; there may be a problem with your computer's video. If the monitor does not work; the issue is the monitor. It will then need to be replaced.
1/29/2011 4:15:45 AM • AOC 193FW LCD... • Answered on Jan 29, 2011
My lcd monitor produces only white screen...what
If you olny getting white glowing screen, it can be the connector to the T-CON board on the LCD panel came off or it has blown fuse on the T-CON board, or the logic board is not sending the 5 or12vdc to the T-CON board.
Please read below:
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Please post back what you find.
10/2/2010 2:59:03 AM • AOC 193FW LCD... • Answered on Oct 02, 2010
How to repair my LCD monitor back light?
take it to a computer tech shop....
doing it is little tricky...and will need expertise on opening brittle equip....
all the best
9/29/2010 5:07:43 PM • AOC 193FW LCD... • Answered on Sep 29, 2010
3answers
I have been using AOC monitor, model 172S for the
You mean the OSD menu? That sounds like a loose solder joint. The button when pressed closes the cicruit and performs that particular action. What is happening here is that due to bad solder joint the button is pressing itself and hence you see the OSD menu. I have seen this problem a couple of times before. If you have good soldring skills you can probably handle this yourself.
8/8/2010 11:39:36 AM • AOC 193FW LCD... • Answered on Aug 08, 2010
Walang Display sa pentium4 pero sa pentium3 Display siya
baka di makayanan ng Monitor mo ang required resulotion ng Video Card sa Pentium 4 mo.
if thats the case.. mag down grade ka sa VGA Card ng Pentium 4 mo or Buy a new monitor that fits the specs of your Pentium 4 setup
7/21/2010 12:06:44 PM • AOC 193FW LCD... • Answered on Jul 21, 2010
No display of monitor AOC!
Power suppply will be the first place to look, look for caps with leaking/bulging tops.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
5/29/2010 1:22:58 AM • AOC 193FW LCD... • Answered on May 29, 2010
Has a blue dialog box that says out of range
Hello
It sounds like you have two separate problems.
The first one is the "out of range" issue. This means you are trying to display a screen resolution that is too high or too low and your monitor cannot display any image. Reboot your computer with another monitor or into safe boot mode and change the resolution to an industry standard (800x600 / 1024x786) and then see if your monitor will display the image. Once you can see the image on your monitor, you can make adjustments and it will automatically revert back if you cannot see the new display settings.
Update your video graphics card drivers to get the best possible resolution.
As for the buttons on the front of the monitor not working, this may be caused by the "out of range" issue above. It could also indicate that your monitor may be going bad. Try the above steps - if you get no image from the monitor, try moving the monitor to another known good computer and see if the button functionality works after it displays an image.
5/4/2010 4:03:26 AM • AOC 193FW LCD... • Answered on May 04, 2010
Could not adjust the display from the monitor
With the monitor turned off, press and hold the Menu button while turning the monitor on. This should unlock it.
3/22/2010 5:24:04 AM • AOC 193FW LCD... • Answered on Mar 22, 2010
0answers
Monitor goes black (just very very very dark! not
It sounds more likely that the back light inverter circuits are not working, check to see if you do have 12vdc feeding the inverter circuits. Check for bad caps (bulging top) also. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
1/20/2010 4:14:29 PM • AOC 193FW LCD... • Answered on Jan 20, 2010
The monitor has an signal, but after 5seconds,,,
owns_mon, "Switch-mode-power-supply"/CCFL inverter supply failure." Check your warranty?? Else visit YOUTUBE and more of my FIXYA profile for your options for repair!!! 12fixlouie
1/5/2010 5:43:06 AM • AOC 193FW LCD... • Answered on Jan 05, 2010
ACER
5/20/2009 9:55:10 PM • AOC 193FW LCD... • Answered on May 20, 2009
AOC 193FW White Display
I WANT ACER AL1921 DRIVES
3/11/2009 9:57:49 AM • AOC 193FW LCD... • Answered on Mar 11, 2009
2answers
How do i adjust the brightness
Hi, please look for a button with a sun icon above it. Usually pressing that button and the using the corresponding arrows on the device should allow you to alter the brightness. Thank you.
11/8/2022 11:45:53 PM • AOC Computers &... • Answered on Nov 08, 2022
AOC 193FW LCD Monitor Logo
29 questions posted
Top AOC Computers & Internet Experts
dannydoesita
Tom Chichester
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AOC Computers & Internet
Most Popular Question
like remove osd warning pop out
  • Computers & Internet
