20 Most Recent AOC Envision L32W461 32 in. LCD HDTV Questions & Answers
My Envision Series AOC TV has blue lines across the screen when its on. Common problem?
This might be a screen driver problem that cannot be easily repaired without replacing the whole screen assembly. It may be cheaper to replace your TV. Ask a repair shop for a repair quote.
6/26/2016 12:29:39 AM • AOC Envision... • Answered on Jun 26, 2016
The screen will turn black but you can still hear it
This sounds like it may be a problem with the high voltage power supply that provides power to the fluorescent tubes that illuminate the screen.
6/25/2016 11:29:07 PM • AOC Envision... • Answered on Jun 25, 2016
How do I get a signal
You need to plug an RF cable into the RF Input. Connect that to a TV antenna, cable, or satellite receiver. You will need to run a channel scan to allow your TV to know what channels are available.
6/25/2016 1:30:27 PM • AOC Envision... • Answered on Jun 25, 2016
2answers
How do I change the
Look for the manual control button the said INPUT.Pushes couple times,now u will move within HDMI modes like 1,2,3.
2/5/2016 2:59:54 PM • AOC Envision... • Answered on Feb 05, 2016
I have an AOC 42 inch hdtv , my problem was it on by it self as well as the volume goes ups and down,I can't even control it by doing it manually or by the remote..
it seem like capacitor is gone, as it is obvious that you do have limited knowledge of the tv, i would suggest sending it to the workshop, most aoc tv have two or three year warranty, you can check they warranty on this site: http://us.aoc.com/support/warranty select product and then model number and follow instructions, if it is still under warranty - your problem is solved, fill online form and that will be that, in most countries they even organise pick-up. if it is out of warranty, on this same site you can find recommended repairer. hope this will help you solve the problem, do not forget to vote...
2/28/2015 1:04:59 PM • AOC Envision... • Answered on Feb 28, 2015
0answers
L32ha91
Be the first to answer 1/15/2014 3:31:34 AM • AOC Envision... • Posted on Jan 15, 2014Be the first to answer
0answers
0answers
0answers
How do i fix or repair 6 black vertical lines on the right side of screen?
Vertical lines can occur due to a loose contact of LVDS cable, to display panel and T'Con board. Re-seat it once and check.
7/12/2013 7:52:11 AM • AOC Envision... • Answered on Jul 12, 2013
No signal hdmi for
If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine and half Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
5/12/2013 6:09:59 PM • AOC Envision... • Answered on May 12, 2013
The source menu on my tv keeps flashing and volumn goes up and down by itself
Pull the batteries out of your remote. Does it still flash and yell at you? If no, replace your remote. If yes, call the manufacturer, they should be able to point you in the right direction regarding your Envision. I'm not very familiar with your model, but it's not a problem I've encountered before. Since your remote doesn't work perfectly anyway, it could be causing exactly what it is that your describing. Your OK button could be stuck in the depressed position, like it's being held down, and since it's usually near the volume buttons, it seems to be the most likely cause.
1/31/2013 5:47:50 PM • AOC Envision... • Answered on Jan 31, 2013
My 6 year old 32inch envision tv no longer has picture or sound anymore even after its properly connected to cable
Based on the brand parts may not be available and six years is better than average life for this type of set.
12/12/2012 3:03:53 PM • AOC Envision... • Answered on Dec 12, 2012
Envision flat screen tv has 5 channels that don't play volume but show pic
Check the volute settigs to these channles. Check whether system set is compactable with input.
2/4/2012 6:14:56 PM • AOC Envision... • Answered on Feb 04, 2012
AOC Envision L32W461 32 in. LCD HDTV Logo
57 questions posted
Top AOC Televison & Video Experts
Ekse
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • AOC Televison & Video
Most Popular Question
need remote code
  • Televison & Video
