20 Most Recent
Philips 26PF5521D 26 in. HD-Ready LCD Television Questions & Answers
26PF5521D wont show menu after reseting factory defaults
Switch the TV to analogue mode (if possible)
Press and hold the "MENU" button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears. (If you let go before the menu disappears, start again)
The TV should now go blank for up to 2 minutes, and then revert to factory settings and intitial installation screen.
Procede as per original installation.
10/4/2013 2:52:00 PM •
Philips...
Answered
on Oct 04, 2013
Television is 6 years old.when
Hi:
Have the power supply checked for leaky or bad buldging capacitors on it. This is the most common reason most LCD televisions fail. Also you may have a bad backlight inverter board.
5/22/2011 5:29:39 PM •
Philips...
Answered
on May 22, 2011
Ref: 26" 26PF5521D model. Following
I'm afraid the electronics have been 'spiked' by the lightning. It may have affected more than one module There is little you can do other than having it looked at by a professional, however you may be able to claim on your insurance?
Regards
2/4/2011 1:00:00 PM •
Philips...
Answered
on Feb 04, 2011
Ref: Philips LCD DVB 26"
You have a diode arrangement in your power supply that converts the AC power to DC power so that it can be stepped up to operate the high voltage power supply of the set. If those diodes are blown, which happens frequently in a storm, then you have no voltage to your high voltage. You are going to have to check that diode arrangement by making a continuity check both ways on each diode. A diode blocks voltage one way but lets it pass the other way, thus producing a DC voltage.
2/3/2011 7:30:33 PM •
Philips...
Answered
on Feb 03, 2011
I have a philips lcd
try changing channels, usually it turns on this way. I turn it on by clicking the up channel arrow.
1/20/2011 6:02:30 PM •
Philips...
Answered
on Jan 20, 2011
Sound fading away
I would not think the speakers are defective but rather faulty capacitors in the power supply circuitry if the TV works good for some time.
6/20/2008 7:05:04 PM •
Philips...
Answered
on Jun 20, 2008
Green line down centre of screen
Defective or Bad LCD panel.
IT will be cheaper to get new TV than to get it replaced. U can check with local repair shop or look for a panel yourself at parts.com for the price of a new panel.
5/3/2008 7:33:53 PM •
Philips...
Answered
on May 03, 2008
Vesa screw holes
Most wall brackets are universal for a particular vesa standard, in this case 100mm x 200mm.
This means that the bolts supplied aren't for any particular set.
The Philips 26PF5521D only needs bolts up to about 12mm long.
Try shorter bolts.
3/14/2008 5:05:44 PM •
Philips...
Answered
on Mar 14, 2008
Philips 26
There is an input imbalance. Either try connecting your cables to different inputs on your TV, or try connecting to different outputs on your DVD player. (Only worry about the yellow video cable bit initially). Alternatively, try a different cable type; you'll have some ins and outs that don't use RCA connectors.
3/3/2008 3:16:16 AM •
Philips...
Answered
on Mar 03, 2008
26" Philips HD ready tv (LCD)
Nothing much you can do. The soft plastic will get worse if you try anything.
The screen could be replaced, but would cost more than the TV.
2/22/2008 12:36:45 PM •
Philips...
Answered
on Feb 22, 2008
26PFL5520D/50 DVT PROBLEM
If the lines across the screen are made up of coloured blocks, then the problem is likely to be a weak signal.
Digital channels are broadcast in groups called multiplexes. Sometimes one multiplex may have a weaker signal than others, and so you experience problems with up to 6 channels when all others are ok.
If it is only one or a few channels then just wait and see what happens, because it may be transmitter works.
If you have problems with all channels it could be a connection or antenna problem.
If the lines are just straight lines, then try resetting the TV as follows:
Switch on the TV
Press and hold the menu button on the side of the set. The settings menu will appear. Hold until the menu disappears again.
When you release the button, the TV will take up to about 90 seconds and then reset.
The TV will then show the original screen when the TV was new.
Press ok when shown.
Set language and country settings.
Move down the list and press ok to re-install all channels.
2/22/2008 12:35:28 PM •
Philips...
Answered
on Feb 22, 2008
TV stuck in DTV mode
It's very simple just remove the TV wire connected to your DVD drive then an option will pump up, asking you whether you want to use it, then select yes that's ok, it's done
1/15/2023 6:48:03 AM •
Philips...
Answered
on Jan 15, 2023
Why my TV is switching off by itself PHILIPS?
It could be a lot of things causing the issue, without electronic knowledge it's going to be hard to diagnose, also a 10 plus year old set isn't worth fixing, parts will run more than the set is worth, time for a new set.
11/28/2022 3:43:55 AM •
Philips...
Answered
on Nov 28, 2022
