20 Most Recent Lexmark E250dn Laser Printer Questions & Answers
Over time the rollers get slick and hard. If one side is slick and the other edge is not, it will grab paper sideways and you get a paper jam. Get some rubbing alcohol and rub the rollers (completely all around) to get some debris removed. Some rollers require a slight rubbing with an abrasive pad.
Lexmark E250dn... • Answered on Feb 18, 2018
Probably you need to purchase new one - Lexmark E250X22G photoconductor. Every 60000 prints you need to change it or If it is OPC drum (green roller) damaged. e250drum-tesepflwvh4nbors0jy4gnro-1-0.jpg
Lexmark E250dn... • Answered on May 30, 2017
You should be able to go to the control panel and search for new devices. If that does not work then go to the Lexmark site and download the software from that site. It will then handshake with your computer.
Lexmark E250dn... • Answered on Apr 14, 2014
I had the same problem on my E250dn. First remove the paper tray. Shut off the printer. Tilt it sideways if it's manageable. Then, clean the 2 rollers directly underneath the printer with alcohol. That solved my problem and hoped yours as well.
Lexmark E250dn... • Answered on Dec 10, 2013
.. add paper ?
Lexmark E250dn... • Answered on Nov 10, 2013
There is a sensor relay arm under the body of the printer in the hole created by removing the paper tray. Look for a long thin peice attached to a spring assembly. There is a wire that plugs in to the relay it may be loose. You might also remove the paper, push the metal peice of the paper tray into a locked postion and then replace your paper
Lexmark E250dn... • Answered on Oct 11, 2013
Nos gustaría saber más acerca de secuencia de luces de la impresora, por favor envíenos la información y estaremos encantados de ayudarle a resolver su problema.
Para obtener asistencia adicional, póngase en contacto con asistencia técnica de Lexmark.
Lexmark E250dn... • Answered on Jun 05, 2013
Visit: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_E250D&focusedTab=DOWNLOADS#1Then select the Operating System from drop down to get the appropriate driver for your Operating System and install it.
Lexmark E250dn... • Answered on Dec 11, 2012
Make sure to enable that under printer properties. Just go to Printers and Faxes > Right Click on the Lexmark icon > Properties > Configuration > Check Tray 2.
Lexmark E250dn... • Answered on Nov 27, 2012
If the light flashing is the "light bulb like button" or the "Ready/Light" button, it means that either the printer is:• The printer is busy receiving and processing data or printing.• The printer is printing a directory, font list, menu settings pages, or Print Quality Test Pages.If it's Busy:• Wait for the message to clear.• Press and release Cancel to cancel the print job.• Press and hold Cancel to reset the printer.If it's printing a directory, a font list, menu settings pages, or Print Quality Test Pages:• Wait for the pages to print. The Busy message is displayed as the pages print. The Ready light is on when theprinting stops.• Press and release Cancel to cancel printing.• Press and hold Cancel to reset the printer.
Lexmark E250dn... • Answered on Aug 24, 2012
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Lexmark E250dn... • Answered on Jul 19, 2012
As a last resort you can uninstall and the reinstall the printer
Lexmark E250dn... • Answered on Apr 17, 2012
Lexmark E250dn Laser Printer Logo
138 questions posted
Top Lexmark Office Equipment & Supplies Experts
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
E Lexmark
  • E Lexmark
Most Popular Question
need windows 7 recognize additional
  • Office Equipment & Supplies
