20 Most Recent Gateway MX6436 Notebook Questions & Answers
Maybe you need more memory on your laptop. How much memory do you have? Click Start/Control Panel or Start/Settings Control Panel and look for System or System and Performance. When you open System it will tell you how much memory you have on the General Tab.
Try using another player to listen to your music such as the VLC Player.
Try using VLC as your player. Go to www.google.com and in the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Download and install it. It downloads and installs in 3 minutes or so. It's a very fast player, smooth and it can play just about any type of dvd formats and media. It's totally FREE.
Gateway MX6436... | Answered on Jun 10, 2012
i assume you have used the fn key and switched it to allow a seperate monitor have you tried it to use both monitors at once if so what happened?
Gateway MX6436... | Answered on Mar 15, 2011
I need to ask first. Are you prepared to completely disassemble the laptop, down to the bare motherboard in your hand, and do you have really decent soldering/de-soldering skills? Post back in a Comment.
For now here is the Gateway M6400 series of Notebook PC's > Service Manual.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
On the top line that starts with Gateway 400, go to the line under it.
Now go across until you reach > MX6400
This is a PDF file.
The computer you are on now has Adobe Reader on it, which uses PDF files.
I would recommend going to Adobe.com however, and downloading the newest version (Free) of Adobe Reader, if the computer does not have it. (Adobe Reader 9)
After you click on the file name MX6400, it may take up to 30 seconds before you see the first page. The file is downloading in the background.
It may also take additional time for the file to fully download.
Suggest you let the file download all the way before looking through it.
This video gives you an average idea of completely disassembling a laptop,
http://www.youtube.com/watch?v=bnkQNmKauEc
As stated, post back in a Comment, and we'll precede.
Regards,
joecoolvette
Gateway MX6436... | Answered on Jan 04, 2011
Hey!
That model does not have built-in speakers. You can verify it through this link.
Hope this helps! :D
Gateway MX6436... | Answered on Sep 09, 2010
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Gateway MX6436... | Answered on Sep 06, 2010
Check it to an expert. Thank you.
Gateway MX6436... | Answered on Jun 08, 2010
If you want real cheap, then an universal AC adapter is your best option. Targus has one that you can purchase for 24.99 USD, which you can find here.
That adapter works for a wide variety of manufacturer's including Gateway. Also, this particular adapter can provide up to 70 watts of power. So any adapter that fits into that range will be fine on power consumption.
Your AC adapter takes approximately 65 watts of power and should be okay.
I hope this help.
-Ernest
Gateway MX6436... | Answered on Apr 22, 2010
What i did is to get a external cd drive
Gateway MX6436... | Answered on Mar 22, 2010
Wow theres a lot of information in that question. Thought long and hard about what you wanted to ask huh?
Gateway MX6436... | Answered on Feb 04, 2010
If you have to ask "HOW" to disassemble your laptop, in order to remove and replace the hinge, then STOP, and take the computer to a qualified technician, who can safely make the repair.
Gateway MX6436... | Answered on Nov 18, 2009
Yes they can and also the power jack may be bad.
Gateway MX6436... | Answered on Jul 28, 2009
you should try getting the driver again but this time dont rename it pls.maybe that would work.
Gateway MX6436... | Answered on Jul 13, 2009
Recommended Solutions :
>>> Re-install Sound driver
>>> Re-install Vista using DVD
>>> Check hardware connections of your laptop to speakers.
>>> Fix sound problems using its Wizard in Vista.
Rate the solution if it was helpful to you...
With Regrards,
Shyny
Gateway MX6436... | Answered on May 28, 2009
Go to your device manager and see if there are any Yellow or Red exclamation marks.
Gateway MX6436... | Answered on May 22, 2009
Do you have any codec packs installed?
If so uninstall them and install these two.
http://sourceforge.net/projects/ffdshow
http://ac3filter.net/project/1/releases
Most popular media player
http://www.videolan.org/vlc/
Gateway MX6436... | Answered on Apr 24, 2009
do you have the driver for the notebook, if so reinstall it and if it is still like that you have to change the speaker.
Gateway MX6436... | Answered on Apr 08, 2009
Not enough information to answer. Need manufacturer and specific model number before we can help.
Generally, though, laptops come with one of three ways to restore.
1. The manufacturer supplies a restore disk. This can be a self-booting image of the original load, or it can be an OS disk and an accompanying drivers disk that needs to be installed to restore the unit.
2. The manufacturer provides an application on the drive that the user is supposed to use at the time of purchase to create a set of recovery disks. This application is usually a 1-time-only thing and you cannot make multiple recovery sets with the app, but you can burn copies of the disk(s) you make.
3. The manufacturer places a hidden recovery partition on the hard drive that allows the user to restore the original factory image. There is usually a hotkey combination written into the BIOS that will divert the boot to the recovery sector when pressed at bootup.
Some manufacturers offer both options 2 and 3. But if you got a set of recovery disks at time of purchase, chances are there is no recovery partition on the drive. Recovery partitions are nice and convenient until the problem is the hard drive itself.
If you can provide a specific model number, we may be able to better determine which type of recovery option(s) are available for you PC.
Gateway MX... | Answered on Dec 01, 2015
It should be a memory card reader. Press in gently, but quickly and plastic tray should pop out.
Gateway MX... | Answered on Mar 03, 2014
Gateway MX6436 Notebook Logo
Popular Tags
25 questions posted
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
MX Gateway
  • MX Gateway
Most Popular Question
mx6436 laptop when listen music cuts out
  • Computers & Internet
