20 Most Recent Philips SA1100 MP3 Player Questions & Answers
0answers
Can delete stuff of it
Hello.
You need to plug it to the computer, and go to the folder where there is voice recordings, click on it then you can delete/copy the files there.
8/14/2010 12:28:19 AM • Philips SA1100... • Answered on Aug 14, 2010
How can i copy sounds onto it
what do u mean by sounds as in music if thats the case then u can use the windows media player to copy stuff to it or u can maunally do it urself by opening up the device on the computer icon the clikc on it twice to find indidvual folder to drag ur music file and drop it on the folder to copy*
12/30/2009 7:39:39 PM • Philips SA1100... • Answered on Dec 30, 2009
Unable to format Philips SA1100 MP3 Player Problem
hievery b
2/20/2009 9:38:51 AM • Philips SA1100... • Answered on Feb 20, 2009
Problem
The songs are in the wrong format - this player does not work with iTunes, and it doesn't support DRM-encrypted WMA's. Convert all of your files to mp3 format, and you won't have a problem.
7/6/2008 8:39:42 PM • Philips SA1100... • Answered on Jul 06, 2008
Seperate Playlists
Use Windows Media Player to create the playlist, and then transfer them to the player by dragging the entire folder to the sync window, instead of dragging all of the files within the playlist to the window.
5/31/2008 12:16:57 AM • Philips SA1100... • Answered on May 31, 2008
Playlist Trouble
Delete the track number from the ID3 tag to get around this problem. Make sure the GoGear is not set to shuffle - make sure the shuffle is OFF.
5/30/2008 9:30:27 PM • Philips SA1100... • Answered on May 30, 2008
My Mp3 Player Only Has 64 Songs Downloaded
check the capacity...it depends on the size of the songs you downloaded...you can check the capacity of your mp3 player by pressing right click and check the properties of your mp3 player
4/28/2008 11:22:55 AM • Philips SA1100... • Answered on Apr 28, 2008
SA1100
This is usually caused by corrupt firmware on the player.
Install the Firmware Manager software from the product CD.
Open Firmware Manager and select the repair option.
3/26/2008 1:48:54 PM • Philips SA1100... • Answered on Mar 26, 2008
Player problem connect to pc
2/15/2008 5:52:09 PM • Philips SA1100... • Answered on Feb 15, 2008
Sa4111
I am not familliar with the SA4111, but it seems to be identical to the SA11XX series.
With the SA11XX freezing was caused by protected tracks or corrupt firmware. The procedure for the SA11XX series is as follows: Removing the battery should reset the player. Check that your files are not protected (DRM). If they are, format the player and load a non-protected test track, and try again. If the player still freezes then install and run the Firmware Manager from the product CD. Select the repair option and follow the on-screen prompts.
2/10/2008 10:25:36 PM • Philips SA1100... • Answered on Feb 10, 2008
SA4111 1GB gogear
These players do not need Synching.
Try dragging and dropping your tracks on to the player with Windows Explorer or My Computer.
2/10/2008 10:21:28 PM • Philips SA1100... • Answered on Feb 10, 2008
My mp3 doesnt play music properly
This is caused by the ground connection from the earphone socket not making contact with the main PCB.
This can be repaired by anyone competent with a soldering iron.
The four contacts on the earphone socket need to be re-soldered.
2/8/2008 8:58:10 PM • Philips SA1100... • Answered on Feb 08, 2008
Hello
2/8/2008 8:52:35 PM • Philips SA1100... • Answered on Feb 08, 2008
I/O device error Philips SA1100 MP3 (512mb)
i dont no how to put songs on
2/8/2008 12:29:21 PM • Philips SA1100... • Answered on Feb 08, 2008
Driver pour mon MP3 ave Windows Vista
www.p4c.philips.com - select Francais - entre SA1110
-Tha Mp3 Doctor
2/7/2008 3:26:14 AM • Philips SA1100... • Answered on Feb 07, 2008
Player problem connect to pc??
i bought mine a few weeks ago and its not connecting to my pc
my copmuter is not even reading it
1/17/2008 6:51:25 PM • Philips SA1100... • Answered on Jan 17, 2008
Philips SA1100 MP3 Player Logo
29 questions posted
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
seperate playlists
  • Audio Players & Recorders
